Old 06-06-2014, 01:07 PM
lfuechtm lfuechtm is offline
2003 Lesabre Limited
Car will not start after a fuel fill. I let is sit for 10-15 minutes and it starts O.K.
Check engine light is not lit.
Is this a fuel pump problem? Or is the evaporative system involved?
Old 06-06-2014, 03:05 PM
Tech II Tech II is offline
Re: 2003 Lesabre Limited
It will not start?
Does the vehicle crank over and not start, or it doesn't crank at all?
Look at the SECURITY light on your dash when you turn your key to on(don't crank the vehicle).....does it go out after 5 seconds, or does it stay on?
This only happens after a fuel fill?
Old 06-06-2014, 03:17 PM
Yes,this happens only on a fuel fill. Otherwise everything is normal.
I can hear the fuel pump run and then stop after a few seconds which I consider normal when I turn the key on. The Security light does go out.
The engines cranks O.K.
Old 06-08-2014, 03:31 PM
I am going to replace the Fuel Pressure Regulator.
Old 06-08-2014, 04:16 PM
maxwedge maxwedge is offline
A990 racer
Check the pressure at the rail 1st.
Old 08-29-2014, 12:34 PM
The fuel pressure is good.
Replacing the fuel regulator fixed it.
Thank you everyone.
Old 08-29-2014, 04:47 PM
But it doesn't make sense....a f/p regulator that somehow fails only during fill ups?
Old 08-29-2014, 09:21 PM
I blame it on a leaking f/p regulator which caused a flooded engine condition after a long idle waiting for a fill-up..
The car runs fine now.
Old 08-30-2014, 12:58 PM
I can see, if you have a leaking f/p regulator having a problem with starting on a hot engine, even causing a stall, because the vehicle is running too rich, and you want a leaner fuel mixture on a hot engine...if it leaks on a cold engine, no problem, because you want a rich condition on cold startup.....
But only on a fill up? still just doesn't make sense....
The Following User Says Thank You to Tech II For This Useful Post:
lfuechtm (09-20-2014)
Old 09-20-2014, 10:53 AM
The car has been fine since replacing the fuel regulator. No further problems.
Old 09-21-2014, 04:24 AM
Blue Bowtie's Avatar
Registered Offender
Thank you for the update. A nearly 30-day test drive is pretty clear evidence of a completed repair.
