Hey guys, I've noticed from other threads that there could be several items that cause interior lights to stay on, but I didn't see any that mentioned a clicking noise in the dash.
First, a quick history. Months ago, i got a random engine misfire. over several months, as time permitted, I replaced various items ( the cheapest first) and checked O2 sensors. I just replaced the cap and rotor a couple of days ago and started it up today. Now, it seems to run fine, except that I hear a clicking noise in the dash. Occasionally, the airbag light came on in time with the first few clicks, then the airbag light flashed. I turned on the interior lights using the dimmer switch, but they would not go off, even when I pressed the override button. Also, ever since I started working on it, the radio will not work. I was never able to turn the radio off from the time I bought it, but I cannot turn it on, now. Lastly, a few weeks ago, after checking the coil and voltage to the coil, I reconnected the battery and all the doors locked automatically (leaving my keys inside was a bad idea!). So, what could be causing the clicking (relay?), why can't I get the radio on, and why won't the interior lights go off? Possibly connected symptoms? Mike |
Re: 1999 suburban 1500 4x4
Since you're having trouble with the interior lights, I would suspect the Interior Lights Control Module is where the clicking is coming from. It is located under the center of the I/P. It is powered by the GAUGES fuse #4 in the I/P fuse block. Pull this fuse and see if the clicking stops. You'll have to put the key in the "RUN" position to check it.
As to your light & radio issues?? Check out this site for factory manuals to help you trouble shoot your issues. http://alldatadiy.com/
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
