Old 06-02-2014, 07:54 PM
skooterbum skooterbum is offline
AC Compressor replacement Q's
I'm going to replace the condenser, and AC compressor on my 1999 Blazer. I've got the parts, and am ready to install them, but I have some questions first.........
Can I drive the Blazer to my mechanic, after installing these parts, to have him then charge the cooling system ??
Or will driving it, before charging the system, damage the new parts ??
My mechanic that's going to charge the system is about 4 miles away from me.
He has no problem charging the system for me, knowing I'm replacing these parts. But he want's nothing to do with hooking anything up to the parts I'm installing, for legal / liability reasons. Which I understand.
I just want to make sure I won't dick anything up driving the vehicle, after installing the new parts. By the way, if you haven't already figured it out, I am completely AC ignorant...LOL
Your advice will be appreciated.....
Old 06-03-2014, 08:40 AM
brcidd's Avatar
brcidd brcidd is offline
Re: AC Compressor replacement Q's
Yes
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-03-2014, 03:54 PM
Originally Posted by brcidd View Post
Yes
I just want to make sure....Yes it's OK to drive it, or, yes it will damage the new parts ??
Thanks.......
Old 06-03-2014, 07:02 PM
brcidd's Avatar
drive it - and don't worry so much
'99 GMC Yukon
The Following User Says Thank You to brcidd For This Useful Post:
skooterbum (06-03-2014)
Old 06-03-2014, 07:14 PM
Thank you sir !!
Old 06-07-2014, 08:45 AM
j cAT j cAT is offline
probably too late now but when replacing the ac compressor you must do the system ac flush . this cleans out any metal debris from the ac system. also any acid.
replacing all seals disturbed and the orifice tube......
installing the compressor oil need be added to the compressor and also the system of the proper type/viscosity/amount.
When you have a shop do the charging and you did this install setup work he will not even check for leaks ...not his problem and also why help you out a person taking away his business...
installing leak detector dye is recommended . this then will reveal leaks,using a black UV light.
good luck..
The Following User Says Thank You to j cAT For This Useful Post:
skooterbum (06-07-2014)
