Old 06-28-2003, 12:03 AM
blade34609's Avatar
blade34609 blade34609 is offline
HELP Please!
Hi,
I have a 200 watt 2 channel amp that can be bridged to 1 mono sub.
Well I hooked it all up with RCA running the oposite way and power and remote turn on the other side.
But for some reason I cant get any sound to come from my sub.
I know my sub is not a problem cause it worked with my old amp.
I dont know that it could be please help!
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 06-28-2003, 12:15 AM
b16a3sol b16a3sol is offline
does the amp have any lights that turn on when the stereo is turned on? if so, what are they?
if the amp says its getting power, then check you wired the sub to the amp properly. you may have just put the wires in the wrong terminals, so the amp cant put out a signal to the sub. also make sure the sub is not grounding out on anything metal.
if the amp is the issue, then make sure its grounded properly. also make sure that all the crossovers on the amp are set to allow low-pass signals get through.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
