Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 05-27-2014, 09:31 PM
bigfartter bigfartter is offline
2002 dodge intrepid wont crank 2.7 l
I have a 2002 dodge intrepid that wont crank over sometimes unless I take the key and keep moving from the start position to the off posion ,then it finally engages.
Any suggestions? I have replaced the battery, but I thought if it was a starter issue, it would click more than once.
Old 02-02-2015, 07:12 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
Re: 2002 dodge intrepid wont crank 2.7 l
Usually a starter will click multiple times if it isn't getting the power from the battery like it should. What I see all the time is the solenoid will lock up and all you get is a single click and after cycling the key several times will sometimes start. A quick check to see if it is the starter solenoid, is to tap on the solenoid when you try to start it, if it starts i'd say its the solenoid. If not.... well could still be but you could have other issues. If you want to go through the hassle you can remove the starter and have it tested.
