Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 05-26-2014, 08:44 PM
tempfixit tempfixit is offline
Disable Air bag
Friend of mine has a 99 Dodge Neon he races and wants to remove or disable airbags to prevent deployment while racing. Removing the fuse for the airbags system be the best or removal of airbags.
thanks
Old 05-27-2014, 08:13 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Disable Air bag
Removing the fuse will work. The driver's side is easy enough to remove as well. (4) 10mm bolts and its out.
2003 Dodge SRT-4
The Following User Says Thank You to das2123 For This Useful Post:
tempfixit (05-27-2014)
Old 05-27-2014, 09:01 PM
Re: Disable Air bag
thanks, that is what I thought but wanted to make sure. Removing the steering wheel air bag should also disable the passenger side as it get current from the driver side bag correct???
Old 05-28-2014, 08:13 PM
Re: Disable Air bag
Not sure about that.
2003 Dodge SRT-4
