Isn't Caprice tougher than Crown Victoria?
In terms of power, torque, looks, etc.? Both cars are real cop cars.
Re: Isn't Caprice tougher than Crown Victoria?
Ford did make out , when GM dropped this vehicle line . taxis also missed these type vehicles. |
The LT1 Caprice was bar none the better car. As for rear end collisions -both cars fared about the same in DOT tests - remember these cars are getting hit by other cars traveling at 75+ MPH - most of the fires in the CVPI were found to be caused by police equipment mounted in the trunk lengthwise and thus impaling the fuel tank in a collision (the fuel tank on the 'Vic is mounted between the axle and the trunk floor - vertically). The solution was a trunk insert/organizer that forced equipment to be placed in laterally - and the insert also had a Kevlar blanket on it to keep things out of the fuel tank area in a collision.
I have a 1988 9C1 with a 5.7 and I also have a 2005 CVPI and they're actually both pretty much evenly matched in most categories.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Sandman - Does that include oil consumption?
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
I haven't noticed any oil consumption issues with mine yet, then I've only put about 4,000 miles on it. Time will tell.
I do know this - the Caprice gets 12MPG and the CV gets 20MPG in the city - that's why I am wanting to do the LT1 swap on the Caprice.
All you need is a converted LT1 intake and ECM/harness from a TPI system and you can have a simple LT1. Then again, with all the donors in the scrap yards it may be just as easy to do a complete swap. I updated a '57 Bel Air, a '69 Camaro, and '72 Chevelle to TPI and the toughest was the '72 due to a very tight dash to work within. Swapping in a late generation Cappy should be cake.
Another thing that might be a possibility is a complete Vortec 5700 swap - what are your ideas on that?
TBI might not net the same mileage as SFI. I know that my '94 still gets 26 MPG in pure highway driving mostly on cruise. That's with enlarged ports, enlarged valves, lumpier cam, tighter chambers, and a little programming. In town the mileage is not as good. I get about 20,000 miles per set (of rear tires).
| The Following User Says Thank You to Blue Bowtie For This Useful Post: | ||
silicon212 (06-06-2014)
Yeah that's what I am thinking, too. I've wanted an LT1 setup for a long, long time now, and now is the time to do it.
Now that I have that other thing, I can afford to park this one and do it right.
