Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-19-2014, 10:47 PM
CharmfulPeace CharmfulPeace is offline
Question 1997 Camry power window problems.
Hello, I have a 1997 Toyota Camry with problematic power windows.
The problem is that they do not work unless the driver side door is open about 80% of the way. Would anyone know what the problem may be, and how I could fix the problem?
Old 05-20-2014, 08:29 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1997 Camry power window problems.
Check the wiring in the bundle between the driver's door and the body. There are probably broken wire(s) in that loom. Repair any breaks found.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-20-2014, 11:33 AM
Thank you for the reply, I will check it out and get back to you.
Old 05-20-2014, 08:05 PM
That was it, checked around the joint area of the door where the wires go in and one of the wires was cut. I fixed it and it is all working beautifully now. Thanks for the reply again!
