Old 05-17-2014, 12:16 AM
JustonG1979 JustonG1979 is offline
Exclamation 2000 Chevy S10 Turns over, but wont run
Hello,
I have 2000 S10 SFI 2.2L 4Cy...It was running fine, and my wife was on her way home from work and it shut off on her going down the road. No sputtering or anything, it just shut off. I got a tester on it, and I'm getting no codes. I asked a couple of people, and several suggested it was the ICM, but no go after replacing. My next thought is the coil packs or even the fuel pump relay considering I dont hear the pump kick on now. I'm just trying to get some ideas on what to try?
Thanks
Old 05-21-2014, 10:27 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 Chevy S10 Turns over, but wont run
Originally Posted by JustonG1979 View Post
Hello,
Thanks
Go to the basics.
Do some testing before throwing parts at it.
Does it have spark to all cylinders?
Compression on all cylinders?
Fuel pump 2 second prime up when key on or starter bump?
Proper fuel pressure when cranking?
Injector pulse when cranking?
Will it start with carb CLEANER SHOT INTO INTAKE?
MT
Old 05-24-2014, 08:21 AM
I havent checked spark yet, but I never hear the fuel pump kick in...
Old 05-24-2014, 09:26 AM
DeltaP DeltaP is offline
Have you heard it in the past? Are you familiar with the sound it makes? Some times it take 2 people. One to listen to the gas filler neck with the cap removed and another person to turn on the key,not starting engine. The pump doesn't run long. HTH
Old 05-24-2014, 09:54 AM
Yea, I've head it in the past, a buzzing nose for a couple seconds, and my fuel gauge would show how much gas is in the tank...but I'm not hearing the pump kick in, and the fuel gauge doesnt move. I put a computer code reader on it when all this for started, but It didnt return any codes, which I found odd. I figured id at least get a code if something was wrong?
Old 05-24-2014, 11:01 AM
aleekat aleekat is online now
The codes is not a instant fix. Just a diagnostic tool. With what you just posted, I would leaning towards an electric issue to the pump. See if you are getting 12volts.
Post back, that's what makes Forums Work.
Old 05-24-2014, 11:07 AM
MT-2500's Avatar
AF - Advisor
Not all problems set codes.
That is why you have to run basic no start test.
Get a fuel pressure gauge on it.
If no pressure cranking on start or key on 2 second prime.
Check that end out.
MT
Old 05-24-2014, 11:57 AM
MT-2500's Avatar
AF - Advisor
On the other hand.
May be true or not true.
My brother in law used to claim his check engine light would come on and blink one time when girl fried was mad and blink twice when wife was real mad and he would get a trouble code saying double trouble.
MT
Old 05-24-2014, 03:55 PM
Check that end out.
okay just for kicks I checked the fuel rail... it shot gas... the last time i checked it, it was bone dry... so its getting gas apparently... fixing to go turn it over and check the fuel rail again
*EDIT*
Okay so maybe that was a fluke... now not getting anything to the fuel rail... heading to autozone to get some starting fluid to shoot into the throttle body
Old 05-26-2014, 08:45 AM
MT-2500's Avatar
AF - Advisor
*EDIT*
A squirt will not do it. You need to have pressure up to specs with a fuel pressure gauge.
NO No on starting fluid.only use carb cleaner for starting aid.
Or run the risk of blowing the dip stick threw the hood and valve covers off and besides it could throw a few tining at your head.
MT
Old 05-26-2014, 09:05 AM
I second the no,no on starting fluid! You'll rue the day you ever heard of starting fluid. That should only be used on high compression engines,like diesels and then only by professionals. Get an inexpensive fuel pressure guage kit at Harbor Freight. Or maybe from a free tool loaner program like at Pep Boys.
Old 05-26-2014, 02:18 PM
Turns out fuse ecm -a was blown
Old 06-06-2014, 02:16 PM
Exclamation Re: 2000 Chevy S10 Turns over, but wont run
Okay help!
New problem... Something keeps blowing the ECM fuse... how do I trouble shoot
