Old 05-15-2014, 07:23 AM
GTRfan01 GTRfan01 is offline
spoon honda s2000
im working on a version of the spoon honda s2000, theres plenty of variations that they've raced but im sticking to a fairly std body, as scratch building a crazy aero kit is not what i want from this model! this is to be a quick build..... i hope.
im using the tamiya s2000 spec v as it comes with the hard top and correct wheels needed for this car.
the tamiya kit seems good as usual....
heres what i plan to do
so far ive preped the body, its now in white primer ready to go for the painting, it will need a masking job obviously, it will be fun doing that 'ripped' kind of look that spoon use on their cars.
it will be my first attempt at such a masking job.
also the std brakes were not so good, i was happy with the diameter of the disk so just swapped out the calipers from a donor rx-7
scratch built roll cage also done and primed.
Old 05-15-2014, 09:41 AM
HondaSan72's Avatar
HondaSan72 HondaSan72 is offline
Re: spoon honda s2000
That's gonna look awesome!! Great idea on using the RX-7 calipers. I really like how the roll cage came out. Good job. Can't wait to see more...
Old 05-15-2014, 07:37 PM
da_ashman's Avatar
Looking good so far! If your handy at Illustrator & can design up that ripped line, you could take the file to a local signwriter & ask them to cut it out of a cast vinyl to use as a paint mask. Most will be good buggers & might do the job for dozen cold ones...
Old 05-16-2014, 03:12 AM
potsie potsie is offline
Very cool idea. I will be following this for sure.
Old 05-16-2014, 05:07 AM
thanks for following again guys....
hondasan;
thanks, the std calipers were horrible, i really needed a good chunky set of two piston calipers i can paint blue and appy the 'spoon' decals to.
da_ashman;
thanks for the idea mate. i will look into it!
Old 05-16-2014, 05:32 AM
heres the decals ive acquired for the build
its two from HD, one is from their 'option parts' series that seems to be made for this car, and the smaller set is just to get the 'spoon' caliper decals from.
Old 05-20-2014, 08:23 AM
UPDATE!
i have painted the body
I had a go using tamiya masking tape and it worked ok, not flawless but i honestly didnt think it would work this well.
if i did it again id certainly be able to do a better job, it was a good subject for my first crack at this style of paint job.
no progress shots, as i honestly didnt know if it was going to work or not, but here it is.
the blue is darker than the actual car as i painted it without any natural light and didnt take enough time to get it right but i dont care, its good enough.
i have noticed, after measuring up where the color break needed to be, that the decals are a little on the large size (remember this decal set wasnt exactly made for this car)
it'll be tight, but fingers crossed they will all fit into place ok.
Old 05-20-2014, 07:19 PM
da_ashman's Avatar
That looks awesome, nice work!!!
Old 05-21-2014, 02:41 AM
lovegt40's Avatar
lovegt40 lovegt40 is offline
ItaloSvensk
very nice progress. yellow is not so easy to manage as color. bravo.
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
Old 05-21-2014, 07:17 AM
bit more progress
interior painted, roll cage fitted with padding and painted also (masking tape covering where the center console will be)
first coat of everything on the chassis, still got more detailing to do here.
half the suspension parts painted
dash part-completed, its all std as per kit apart from holes drilled for roll cage to fit into and race steering wheel stolen from a fujimi accessory kit ive had lying around....still need to add some switches and guages
Old 06-09-2014, 03:50 AM
small update...........
rear suspension cradle all done
and fitted.....
exhaust also done, i scrapped the std stuff from the cat back and made my own.
next up is finishing off the paintwork on the body and clear coat.
Old 06-10-2014, 04:09 PM
HondaSan72's Avatar
Loving the updates... Exhaust looks sick!! Great idea!!
Old 06-10-2014, 09:21 PM
Updates are looking great. The roll cage is particularly nice.
Old 06-11-2014, 05:43 AM
thanks for the comments.
the exhaust was easy to make, just different diameter styrene tube.
the tip is a metal tip however. ill take some better shots of it once its all done.
Old 06-19-2014, 05:38 AM
i wish the weather would warm up so i can clear coat the body
