Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 05-13-2014, 08:16 AM
sfmedic200 sfmedic200 is offline
2006 Jeep Liberty Troubleshooting Overheating Issues
I have a 2006 Jeep Liberty 2wd (V6-3.7L) with 150k miles that has been overheating on the dashboard temperature gauge for the past few weeks. I have replaced the radiator, water pump, thermostat, and the sensor for the temperature gauge.
The vehicle does not actually seem to be overheating (no bubbling when cold, no smoke, both rubber hoses to and from radiator get warm and feel like coolant is running through them, etc...). The fan turns on just fine and the a/c and heater work. The vehicle still reads on that gauge as overheating though and it occurs when driving on the highway or stopped at a light. It takes about 10 minutes for the car to warm up and as soon as it does, the gauge starts to go up. When I turn the heater on full blast, the gauge will start to go down. This is no fun in the Texas heat, so I am looking for another solution.
The serpentine belt looks good and the oil looks good (changed Saturday). There are also no coolant leaks and the car does not use a lot of coolant.
Is it just a short in a wire causing the gauge to read hot? Should I start worrying about a head gasket? Is it just the relay or a fuse? Should I replace the fan even though it is working? Any ideas are appreciated as this is my first JEEP.
Old 06-07-2014, 08:24 AM
2000izusu 2000izusu is offline
Re: 2006 Jeep Liberty Troubleshooting Overheating Issues
do a combustion test on the antifreeze. kits are available at auto store
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Tags
coolant , jeep , overheat , overheating , radiator
