Old 06-27-2003, 03:55 PM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
help trottle body prob?
hey i have a std civic hb and i had a shop do an engine swap for me it has a jdm carberated engine changed to dpfi, std throttle body and 88 dx computer, trannie and axels.
could there be a problem w/ not having a throttle body from a dx? i know stds are bad and all but
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 06-27-2003, 06:23 PM
kris's Avatar
kris kris is offline
Off playing with fire.
What problems are you having...
Old 06-27-2003, 08:00 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the same as all his other posts ill assume.
anyway, from what i think is that you have some serious vacuum problems like a leaking intake gasket, spray water&soap mixture over all the parts in your engine where a gasket is or the end of a hose, i recommend using a spray bottle for this.
that way the mixture will bubble if air is escaping.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-27-2003, 08:22 PM
kris's Avatar
I havent read all his other posts.
Old 06-27-2003, 08:28 PM
crxlvr's Avatar
prolly would explain something, i guess.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-27-2003, 08:50 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
If by now you HAVEN'T taken it back to them to fix it then you are an IDIOT!!!!! They performed the swap, you have every right for the car to run. FFS - they are mechanics, the expectation is for the car to run, TAKE IT BACK!!!!!
Other than that, check for vacume leaks, but I bet you that if it's the JDM twin-carb then it's emissions controls are different, the distributor advance will be different and that as a hybrid of a real carb engine with Fi that WAS NOT DESIGNED FOR THAT VARIENT OF THE MOTOR (XT25, GL etc) of course there are going to be issues. Guesses would be vacume hoses (replace them all in case, a good plan anyway), gaskets (spray and look for bubbles as suggested), correct distributor to match the Fi.
By now common sense would suggest that they fucked it up - take it back and tell them to fix it.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 06-27-2003, 09:14 PM
hey
hey i got an appt w/ the shop monday they were really buisy until then.
actually the problem i'm talkin about is that it still performs like an std. sorry i forgot to mention it i have not had enough sleep i actually found out that the noise is shot bearings on my ac compressor what i'm hearing is metal against metal @ high speed. should a known about that but i don't think that's the only thing draining my horse power. so i'm still asking around. lemme know if you get sick of it.
Old 06-27-2003, 09:18 PM
crxlvr's Avatar
metal against metal? you prolly have no damn oil in the engine, but like setanta said, take it back to the hicks who swapped your motor, they damn well better fix plus whatever damage it cuased to your motor not running right.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-27-2003, 09:21 PM
hey i'm positive the noise is the ac compresser it stoppps and starts up again in conjunction w/ the noise it was an anchient compressor. i'm just wondering if somethin else is wrong.
Old 06-27-2003, 09:23 PM
crxlvr's Avatar
take the belt for the ac compressor off and see if you still have the same problems(im sure you will) the ac comp should not cause the symptoms your describing, even still take it back to the installer and say the motor doesnt run right, they should fix it for you since they did the work.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-27-2003, 10:06 PM
i'm taking it back monday but i'm gonna have to pay cause i got a discount on my instilation. but on a plus side i'll prolly get a discount on the work they do!!
i shouldn't have bought a project car w/ this little budget
Old 06-27-2003, 10:09 PM
crxlvr's Avatar
so you got a discount on the swap, doesnt mean they should discount on the quality of the work, you payed to have a motor installed and running, and know you got a piss-poor performer.
i wouldnt give em another dime.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-27-2003, 10:13 PM
i always get a discount at that shop i spent enough there i've been going there for over a year and if something is simple they will not do it and tell me to get my ass home and whip out my tools i think it was an existing problem that was there before the swap but if they fucked up they aren't gonna charge me
