Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 05-10-2014, 01:46 PM
DFBonnett DFBonnett is offline
2004 Express RAP problem
Most times, but not all, opening the drivers door after turning off the ignition shuts down the RAP as it should. Occasionally it does not and I have to open and close the door multiple times. If I get out and open and close any other door the RAP turns off. This situation is particularly noticeable in cold weather. Am I correct in assuming that there is a switch in the drivers door that has become sluggish. I'm hoping to confirm my suspicion before I take the door apart. Any guidance would be most appreciated.
Old 05-12-2014, 10:19 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2004 Express RAP problem
A good body capable scanner should read out if the door switch is on or off.
MT
Old 05-16-2014, 04:54 PM
Thanks for the info. How can I access such a scanner?
Old 05-17-2014, 10:26 AM
MT-2500's Avatar
AF - Advisor
Most good repair shops have them.
AND For a labor of .5 to 1 hr. they will readir out for you.
Or 4-8 grand will buy you one.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
DFBonnett (05-17-2014)
Old 05-17-2014, 12:27 PM
Many thanks. I guess I'll just open and close a different door to shut it off until next year when I retire and the van will become someone else's headache.
Old 10-04-2014, 01:04 PM
I've isolated the problem to sticky door switches. Sometimes they work right away, sometimes in a few seconds. The RAP timer always works after 10 minutes. Nothing I choose to worry about now that I'm sure the battery won't go dead because of it.
