Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-06-2014, 05:13 PM
hidden1 hidden1 is offline
Torque specs
What is the torque supposed to be on my 98 camry 4cly valve cover nuts-4 of them and are 30 mm.?Ive heard some say its 33 and others 17.It has about 175k on it and a small leak at gasket from nut being a little loose.
If i decide to replace gasket is there anything inside i may want to check when cover is off?
Any info is appreciated
Old 05-07-2014, 11:38 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Torque specs
Torque is 17 ft-lbs (204 in-lbs). Tighten from the inside out in 70 in-lb increments. Check the torque again after a week or two of driving. The reason for the confusion is that some manuals have the 33 ft-lb number as a misprint. I don't know where they get that number, but it will crack your head cover as others on this forum have found out.
See the discussion in this post: http://www.automotiveforums.com/vbul...6&postcount=73
Check the PCV valve while you have the head cover off. Also, be sure and clean off all form-a-gasket still attached to the head or cover, and all gasket surfaces in general.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
