Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 06-27-2003, 01:29 PM
BLottman BLottman is offline
Laser Overheating
I have a 1990 Plymouth Laser, 1.8L, that continues to spill coolant by overflowing the coolant recovery tank. I replaced the electric fan motor since that was definitely not working, upper and lower radiator hoses, and installed a TEE flush kit. Backflushed the system.
Symptoms: Upper radiator hose is hot to touch so I know the thermostat is working. The radiator cap had quite bit of grit on it and I cleaned it up and returned it to operation. The water temperature guage indicates normal engine water temp after driving for 10 miles. When I shut off the vehicle, the coolant recovery tank begins filling up and overflows.
How do I tell if the water pump is the suspect?
How do I tell if the electric fan is working and at what temp should it kick on.
Thanks much.
Old 07-15-2003, 11:10 PM
ii0oo0oo0oo0ooii ii0oo0oo0oo0ooii is offline
are you sure the fan is operating? That is usually a sign that the fan isnt cooling it off. check the connections (electrical) for the fan, and make sure that it turns on and off.
If it aint broke dont fix it
Old 07-16-2003, 02:40 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
I agree with the fan idea. Turn on your AC...pop the hood, and make sure at least 1 fan is running at that point. I'm not sure what temp they kick in at on a 1.8, though.
Kris
2012 Genesis Coupe 2.0t
