Go Back   Automotive Forums .com Car Chat > Chevrolet > General Discussion
Old 05-02-2014, 10:12 PM   #1
jimmy73077
need suggestion plz
I have a 1982 chevy 1 ton dually I am trying to check my rear brakes. I am having trouble removing the drums off the diff. i have removed the axle shafts and nuts that hold the drums on but all I can seem to do is wiggle 1 drum and slide the other. Any suggestions would be greatly appreciated
jimmy73077 is offline   Reply With Quote
Old 05-03-2014, 01:22 AM   #2
Crvett69
Crvett69's Avatar
Re: need suggestion plz
you probably need to back the brake shoes off from rear side of the drum, usually takes 2 screwdrivers or a screwdriver and brake spoon. each side will have 2 nuts, make sure you remove them both. also those drums are fairly heavy, be carefull
Crvett69 is offline   Reply With Quote
