Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 05-01-2014, 10:10 AM
Stevenix Stevenix is offline
Starter problem....
My 2009 Sonata with 2.4L engine sometimes turns on the starter when the key is not in "Start" position. For instance, if you turn the key from the "Off" position to the "On" position, the starter starts the car. Other times, if the engine is on (with the key in the "on" position of course) and I move the transmission shift from "Drive" to "Neutral" the starter starts and grinds against the engine. It stops if I flip the key from "On" to "Start" and immediately release the key back to "On",.....and it also stops if I move the gearshift from Neutral back to Drive.
I have tried squirting a little lubricant down inside the key opening, just to try something, but it does not seem to help.
Does anyone have any idea why the starter would start without the key being in the "Start" position?
Steve
Old 07-03-2014, 11:51 AM
Re: Starter problem....FIXED
OK, after replacing the Key Cylinder I still had the problem. I broke down and took it to the local dealer. It was just the starter switch, a $20 part (instead of the$120 part I had replaced) but it still cost me $200 before I was out of there. Oh well, live and learn.
Steve
Old 07-06-2014, 08:26 PM
twospirits twospirits is offline
Ex-Janitor of AF
Thanks for the update.
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
Tags
auto , ignition , problem , starter , startup
