Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-30-2014, 03:36 PM
bagwellbill bagwellbill is offline
accesory vacuum line cause misfire?
so my car has been missing after a recent spark plug change, so i did a smoke test and i see smoke coming from under the air cleaner and i see that the accessory vacuum line goes under there, could this be the cause of the misfire? i already checked all the sparkplug work and wires. and if this could be the problem how would i get to it 1998 buick century 3.1.
Old 04-30-2014, 09:45 PM
Tech II Tech II is offline
Re: accesory vacuum line cause misfire?
You did a smoke test on the evap system? Was there an EVAP code set?
Was a P0300 set?
Old 05-01-2014, 12:50 PM
rkvons's Avatar
rkvons rkvons is offline
Was it missing prior to the spark plug change? I mean if it wasn't, then I would be checking that over more thoroughly. Like, do it over. Maybe a spark plug has a crack in it. Maybe a bad gap. Etc. Also, if there is a miss, you must have a code. What is it?
Tags
buick , century , misfire , sparkplug , vacuum
