Go Back   Automotive Forums Car Chat > Buick > Buick Classics
Buick Classics Discuss older classics here.
Old 04-28-2014, 12:55 PM
John1397 John1397 is offline
81 Buick Skylark
I have a 81 Buick Skylark with 2.8 v-6 engine auto transmission, it gets 39.8 MPG on highway with 10% ethanol fuel I was thinking of adding hydrogen and oxygen to the carb only small amount wonder if it will boost gas mileage?
John
Old 04-28-2014, 07:05 PM
maxwedge maxwedge is offline
A990 racer
Re: 81 Buick Skylark
You are kidding here right, 40 mpg, not possible unless downhill with a tailwind, the rest, connected with the original mpg claim, doesn't warrant an answer. Sorry that's the way I see it.
Old 04-28-2014, 08:48 PM
Should mention I only drove 45 MPH and it is flat terrain on the interstate, I also made a lot of changes since it left the factory.
John
Old 05-15-2014, 02:09 PM
Speculant Speculant is offline
What did you do to it to increase MPG that much?
Old 05-15-2014, 07:57 PM
I had most of the car apart so I made a lot of changes along the way such as mufler has hole cut on inside pipe, catalytic converter is straight thru, prom is not factory no more, air spins into carburetor, egr is closed causing higher temperature, moly grease on everything and tires are bigger.
John
Old 05-15-2014, 08:15 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
hydrogen and oxygen added to carb sounds like a nice way to start a fire or a explosion
Old 05-15-2014, 08:23 PM
So basically, you created a car that has terrible emissions and is much louder than stock to save a few bucks on gas. Great.
In an effort not to be a total dick, here's some links that might answer your question:
http://www.aardvark.co.nz/hho_scam.shtml
http://www.popularmechanics.com/cars...ileage/4276846
This question has been answered and tested over and over. Google is your friend, use it.
Old 05-16-2014, 07:15 PM
Not as long as you do not get a spark in your generating container.
