Old 06-27-2003, 09:32 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Started up the ZC...
I finally started up the ZC I just put in and theres a couple things wrong. One, when I step on the gas, its like the response is really slow. It sucks really hard then revs. Also, its throwing three codes: 4(coolant temperature), 7 (throttle angle sensor), and 8 (TDC position). What can I do about 7 & 8? Also, does anyone know if the fuel pressure regulator from an HF is the same an an Si? Does it allow less fuel flow or anything? And one more thing, do the integra computer codes mean the same things as the civic codes or are they different? Thanks in advance.
Old 06-27-2003, 11:23 AM
anyone? Im pretty desperate here.
Old 06-27-2003, 11:35 AM
Tanked Tanked is offline
If you converted from DPFI, Did you reverse the TPS connection wires?
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 06-27-2003, 11:55 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
#4 I guess means get a new coolant temp sensor, or make sure it is plugged in.
#7 is TPS sensor. When getting used engines a lot of times they come with broken TPS sensors.
#8 TDC most likely means your belt timing is off.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 06-27-2003, 03:01 PM
First of all, thanks a lot for helping me out.
The car was an Si so I dont need to do this right?
Theres a plug on the backside of the engine under the intake manifold that isnt plugged into anything (cant find where it goes) I wonder if thats it. Fourthgen, did you have any extra connectors? Also, I just got a new TPS from the j/y but i wonder if that one was bad too. And I thought the timing was dead on because the two lines on the cam gears lined right up, maybe it is wrong though im gonna go check it out
Old 06-27-2003, 03:48 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Did the crank pulley line up with the cams?
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 06-27-2003, 04:09 PM
yea, seems like it did
