Go Back   Automotive Forums Car Chat > Chevrolet > Uplander
Old 04-26-2014, 11:10 AM
tschmidt tschmidt is offline
Antifreeze drip
I have some antifreeze dripping from the driver side. I can't see where its coming from. I took out the plastic in the fender well. I am not sure if it could possibly be the water pump or the freeze plug. Does anybody else have any ideas? I thought about maybe getting some of that dye that glows with the black light. Not sure if these pictures will help.
Old 04-28-2014, 12:33 PM
rkvons's Avatar
rkvons rkvons is offline
Re: Antifreeze drip
You should look from the top. Take out your air intake ductwork and look around on the driver's side. This is where your hot water lines go to the firewall. Also, there are a couple of small water lines that go to your intake. You can feel around in there when the engine is cold and see if anything shows up on your fingers.
Old 04-29-2014, 03:34 AM
Re: Antifreeze drip
This is dripping from the passenger side.
Old 04-29-2014, 03:36 AM
Re: Antifreeze drip
Made a mistake on my first thread it is dripping from passenger side not drivers side. Sorry damn 3rdcold shift has got me all crazy.
Old 04-29-2014, 11:43 AM
rkvons's Avatar
Re: Antifreeze drip
Not sure about what engine you have, but there's a good chance your water pump is on the passenger side. I would take a look at that. Also, your lower radiator hose connects over there.
The Following User Says Thank You to rkvons For This Useful Post:
tschmidt (04-29-2014)
Old 04-29-2014, 04:08 PM
Tech II Tech II is offline
Re: Antifreeze drip
Sometimes when it is hard to find the source, coolant dye and a black light does the trick....
The Following User Says Thank You to Tech II For This Useful Post:
Old 04-29-2014, 05:13 PM
Re: Antifreeze drip
It has the 3.9 liter
Old 04-30-2014, 07:00 PM
j cAT j cAT is offline
Re: Antifreeze drip
best to wipe and wash it down .. then when it is dark out use a light to see where its leaking and use a mirror. the fluid looks oil like but ????
if your sure its coolant then being in that spot could be the water pump ...
