Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-27-2003, 03:13 AM
blade200369 blade200369 is offline
i need answers
ok first of all i already ask this but no one answered any of these questions. CAN 97-98 240SX HEADLIGHTS FIT ON 95-96 240SX. ALSO HOW MUCH HP AND TQ DOES THE SR20DET AND RB25DET COME WITH.
Old 06-27-2003, 07:10 AM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
sr20det - 205 hp
rb25det - 250hp(althought its been said to make up to 280 stock so I don't know)
torque is probably about the same as horsepower on each
I don't know about the headlights but my guess is yes
Old 06-27-2003, 10:11 AM
GB Phoenix77 GB Phoenix77 is offline
the RB25 is usually good for more than 250. 280 is definitly possible. I don't think I have ever seen a dyno sheet though.
The SR20det varies in hp and tq depending on year.
the S13 (Redtop or Blacktop) put out 205.
The S14 puts out 220 or 225?
The S15 puts out 250ish?
Check out the Faq's thread... it's a sticky on the top of the 240 page. That will answer the questions better.
You can fit Kouki (97-98) headlights on a Zenki (95-96). But, you will have to also update the fenders and hood.
Old 06-27-2003, 03:53 PM
Suislide's Avatar
Suislide Suislide is offline
correct. the Kouki lights will fit, but in order for them to work properly, the hood, fenders, grille, and bumper need to be changed to Kouki-style as well.
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 06-27-2003, 04:19 PM
dekand dekand is offline
Send a message via AIM to dekand
yes the Kouki's will fit, all the oem parts from nissan for the swap will run you about 1800$ or so... im doing it after my motor and everything else.
Old 06-27-2003, 09:06 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
97-98 headlight conversion
http://www.zilvia.net/faqs/archive/koukiconversion.asp
Old 06-27-2003, 11:51 PM
ThaLegend ThaLegend is offline
will it look exactly like a 97-98 even the clear corners... because I have seen that conversion but the side lights {clear corners} still look like the Zenki and I dont like that but if they are changed to the Kouki then Im going to do that as well.
Old 06-28-2003, 11:27 AM
Suislide's Avatar
go to a junkyard and find a 97-98 240SX that has been in a rear-end colision, and just buy the entire front end. it should bolt right on to your Zenki and will look exactly like the Kouki. of course, you'll need to Kouki S14 tail-lights too to make it complete.
-Brian
Old 06-28-2003, 09:53 PM
Thanks for the Info
Thanks im going to go check out my local junkyards for the shit that I need.
