Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 04-19-2014, 11:17 AM
edwinn's Avatar
edwinn edwinn is offline
Buick Enthusiast
PCV kit - easy question
1997 Riviera - 3.8 Liter, L36 - 141,374 miles
Late last year the Delco guy gave me a PCV kit as a credit for some parts that were defective. Below is a photo of the kit. Pointed out there is a locking tab or 'tooth' in the slot.
The PCV valve on the Riv is at the end of the Plenum near the Serpentine Belt. The SM shows the PCV located behind the engine and near the firewall. THAT is confusing. Is one for the supercharged engine? My SM is 1999 G-Platform, and this is a 97 model.
See below the setup is different, and the retainer 'locking tooth' is pointed out.
The PROBLEM is.. the retainer is on TIGHT, and I can't seem to rotate it loose with any reasonable amount of torque. The whole stem is flexing and the fear is it will snap!
How do you guys get that bad boy apart w/o damage?
-Ed
Old 04-19-2014, 11:47 AM
Tech II Tech II is offline
Re: PCV kit - easy question
Easy.......just open a pair of channel locks and grab the base of the retainer, and rotate CCW......when you pull the PCV valve out, the black o-ring usually stays stuck down in the plenum..just pull it out......apply petroleum jelly to the black o-ring, insert it on the valve, and put the valve in the plenum...apply jelly to the orange ring, insert on retainer, along with the spring, push downward and rotate CW....easy, peasy, lemon squeazy....
On the SC'er engine, there is a plate above the PCV valve, I think.....naturally not in the same position as the aspirated engine...
The Following User Says Thank You to Tech II For This Useful Post:
edwinn (04-19-2014)
