Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-18-2014, 07:44 PM
IFallsRon IFallsRon is offline
Header door actuator door area photo or diagram
I've had trouble for years with the arm that I'd guess comes from the actuator and controls the blend door on my 98 Sub. It falls off and I reach in and put it back on the spindle. Several weeks ago I picked up a spring near the gas peddle. Today I found the piece that fits on the spindle. I need to figure out how to get it all back together. Anyone who has been in that area knows you can't see. I'd like a photo or diagram to know what it should look like when I try to put everything back together. Fortunately it's warming and I don't need the defrost too much until I figure it out.
Old 04-18-2014, 09:34 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Header door actuator door area photo or diagram
It is normally the arm that drives the defrost door that comes loose- it goes straight up above the gas pedal-to the defrost door. To see how it is assembled look at the arm next to it. I put these back on all the time, and usually use a little JB weld on the end of the shaft it mounts to, to assure it stays put. The best way, if in doubt still, is to go look at another 95-99 GM C/K truck- try a used car lot if you have no buddys who drive one.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 04-21-2014, 07:05 PM
Re: Heater door actuator door area photo or diagram
I'm missing the white plastic collars that surround the spring like the one in the picture. I'll check with the dealer and a local parts yard.
