Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 04-14-2014, 10:12 PM
leroge leroge is offline
Question Oil Pressure Guage Reading Very High
I noticed recently that the pressure gauge 'pins' upon startup on my '93 Wrangler 4.0 ( 97K miles ). Car seems to run well for periods of time without any high engine temp. I've experienced this before but the pressure gauge returns to normal after a while. Could the sending unit be bad?
Old 04-16-2014, 03:30 PM
Wink Re: Oil Pressure Guage Reading Very High
I think I found the problem. When I turn the ignition key on without starting the engine, the oil pressure immediately pegs to 80! Since there is no pressure, the reading is obviously incorrect. Can anyone confirm this?
Old 04-17-2014, 06:41 PM
rhandwor rhandwor is offline
I would go to Auto Zone or Autozone and get a loaner manual gage check your oil pressure.
Normally if you ground the wire to the sending unit and turn on the ignition on it will peg. Maybe your sending is grounded or has high resistance.
Tags
high , oil , pressure
