Old 04-14-2014, 02:37 AM
nascar49's Avatar
nascar49 nascar49 is offline
Send a message via AIM to nascar49 Send a message via Yahoo to nascar49
Meng's Ford F350
This one hit the bench tonight, I am still not sure what I am going to do this one, but I am pretty sure it will be stock for the most part, on to the kit,
taking a look at the frame
A fellow club member suggest that I should drill out the holes on the frame, so I took used his idea, so here is before
and after the holes were drilled
and a mock with the cab/interior
and I opened up the hitch receptacle
And getting some of the pieces on before I paint it
and some paint , used a too hot of black, so it crazed the frame, whoops
Pheedens Garage on Youtube
https://www.youtube.com/channel/UC4j...J8vUP1ZaHP32ig
Old 04-14-2014, 02:55 PM
guillote68 guillote68 is offline
Re: Meng's Ford F350
Awsome kit, big for shure.
Im siting here with popcorn ti view this build!!!
Guillermo
Buenos Aires
Argentina
Old 04-14-2014, 07:19 PM
nascar49's Avatar
More work on on chassis
Old 04-14-2014, 08:43 PM
blubaja's Avatar
blubaja blubaja is offline
Box kit looks great! The tires tho..ugh...Great in detail, but not for a work truck.
Old 04-15-2014, 07:17 PM
nascar49's Avatar
Started work on the engine
And more on the frame, got the tie rod and stabilizer bar on, now there is an small issue with the stabilizer bar, it was real, it wold not being doing a good job of keeping things stable, as you can see, its just a tad bit short, and does not reach the axle
Old 04-16-2014, 05:55 PM
nascar49's Avatar
Body parts in primer
And after removing the mold/seem lines
Old 04-17-2014, 07:53 AM
Serioga's Avatar
Serioga Serioga is offline
Hello nascar 49!
How good are the tyres in your kit?
My was crumpled in a bag and some of them saved this condition on discs. It is because they sit too free (no tight) on rims.
"Precious and fragile things Needs special handling.."
Old 04-17-2014, 09:28 PM
nascar49's Avatar
Originally Posted by Serioga View Post
Hello nascar 49!
The tires in this kit were good, no issues, but I do agree, the fit on the wheels is very lose.
And more work on the engine, its not finished yet, just to point that it gets installed on the frame
Old 04-17-2014, 10:06 PM
Twowheelsrule Twowheelsrule is offline
Thanks for showing so many steps of your build! I have ordered 2 of the Meng kits and reading your post will really help me with my kits!
Old 04-22-2014, 08:20 PM
nascar49's Avatar
I guess I should update, and if I hadnt been screwing around, I probably could of almost finished this one up a few days ago, but no, so what I have done so far, well, lets take a looks see shall we
painted the engine are black, primer in the interior are, and you can see that all the sink marks are on the inside
painted the fan , and installed
started work on the interior
I did not upload the pic, but I put a piece of sheet plastic behind the compartments on the door panels
and a few shots of the seats in color
And finally decided on a color, one of things that has been slowing me down, yes, boring white .
Old 04-22-2014, 08:38 PM
nascar49's Avatar
Old 04-25-2014, 05:07 PM
nascar49's Avatar
I was hoping to of had this one finished last night, but the hobby gods decided they didnt like that idea, I found the major flaw in this kit, when you put the side window pieces in, the cab will not sit correct over the interior , it all has to do with the side window pieces, with out those in place, the body fits perfect , so in the process of trying to figured out what was going on , I chipped a good size piece of paint off , down to the bare plastic , so I am trying to strip the cab so I can repaint it.
Old 04-26-2014, 04:01 AM
generationx's Avatar
generationx generationx is offline
Sorry to hear about your troubles - generally this looks like a well-detailed kit.
Old 05-02-2014, 07:37 PM
nascar49's Avatar
Old 05-02-2014, 07:55 PM
nascar49's Avatar
Just need to add the running boards , and a few things to the engine compartment ,and its done
