97 T-Bird - Starter Switch/Wiring Issue?
97 LX 3.8L V-6. Very well maintained car. She said it cranked a bit slowly on her last drive. Now wont crank at all, or even click the solenoid. Brand new battery. Voltage is good. I jumped battery to start terminal on solenoid, and it turns over nicely. Flipped on the key and again jumpered start terminal, car starts right up. It has the solenoid mounted on the starter. The wire to the terminal is secure, no sign of corrosion. Did not have my voltmeter or even a test light with me to check for start signal voltage at terminal. Looking for possible causes of no signal or insufficient start signal voltage or current. Could it be the key switch/start switch? (If so, where is it located, at key switch, or in column)? Or possibly the supply to that switch? Thanks in advance for any advice/guidance, Iam really not familiar with the Bird.
-Jim.
-Jim 2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4 2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck 1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...). ![]() 1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint! 1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now). |
Re: 97 T-Bird - Starter Switch/Wiring Issue?
Obtained a wiring diagram, tested for a start signal at the trans range sensor, nothing. Checked at the anti-theft output, nothing. Input, nothing. Guessing it is probably the ignition/starter switch. Possibly even adjustment of same. Do these use an actuator rod through the steering column, like a GM car?
