Old 06-26-2003, 10:56 PM
90civichatch 90civichatch is offline
Send a message via AIM to 90civichatch
SOHC Vtec
My car is almost dead so I decided to swap it. Since I'm on a budget I thought I'd go D-series vtec. To those of you who have Vtec D16 swaps, how are they, are they worth the money? Also how much did you guys pay for your swaps? I know it's nothing like a B-series swap but money is tight, so tell me what you guys think.
-Derek.
1990 Honda Civic Shit-box, Sold.
Old 06-26-2003, 11:12 PM
91civicDXdude's Avatar
its great for the money.
Old 06-26-2003, 11:18 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
definitley one of the better d-series swaps you can do ... if you dont have an SI however, most people reccomend going with the d16z6 (92-95 civic ex) over the d16y8 (96-00 civic ex) due to less wiring headaches
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-26-2003, 11:21 PM
actually, now that i've had some time to think about the swap, i would/'ve rather had a d16y8 simply for the fact that the OBD0 distributor goes right on. its not that the distributor hack is THAT hard or anything, it just would've been less of a pain in the ass if it just bolted right on.
Old 06-26-2003, 11:40 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
yea the dizzy is cool although there is very little adjustment. BUT as you know honda likes to change the impedance (sp?) of injectors every few years....so, there is a slight issue there. there isn't enough info out there to clear up some grey areas where the z6 has been done many times...many info site avalible.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
1st off i bought my motor for 600, i have an si so i used maily the parts i had got a new clutch and such, and i have the fields vtec controller and i love it
deff better than the a6 and i did the install myself so that was free, where are you located in md?
and my dizzy bolted right on the right way with the 1 bolt and washer it doesent leak or anything
2002 Acura TL Type S
1991 Honda Crx Si
Old 06-26-2003, 11:42 PM
amy@af's Avatar
oh yea...i almost forgot...
go to www.4thGenerationCivic.com and check the engine section for links on how to for the swap
Old 06-27-2003, 08:36 AM
I live in White Marsh near the Mall. What should I expect to pay for the motor, A6 tranny and anything else I'll need for the swap? Also, how much should I expect to pay for the labor? I don't know if I'll be able to swap it myself. Thanks.
-Derek
Old 06-27-2003, 11:16 AM
amy@af's Avatar
labor should be $500 or less....depending on location
si tranny 200-300
wiring (jumper) conversion ecu harness $150
p28 ecu (92-95 Si/EX)
92-95 d16z6 $300-500 or 96-00 EX d16y8 $500-900+
you can skip the conversion harness and ecu and substitute with 88-91 Si (pm6) ecu and a rpm activated switch (for vtec controller)
like i mentioned above...stop by the engine section for more info
Old 06-27-2003, 12:00 PM
Okay thanks. There is a shop near me that swaps Hondas all the time, so I'm going to give them a call. I'm really looking forward to swapping my car, my D15 just doesn't cut it anymore.
-Derek
Old 06-27-2003, 01:49 PM
dont be suprised if its an outrageous price, shops around here quoted me like 1700 i believe for the sohc vtec installed.....i saved myself about 850 bucks doing it myself and it wasent that hard
1991 Honda Crx Si
