Old 04-05-2014, 10:50 PM
NADCguy83 NADCguy83 is offline
Send a message via AIM to NADCguy83
Question 1996 Chevy C2500 Suburban 350 V8 Hydroboost brakes.....truck pulls hard left
This problem is driving me nuts. The truck WAS pulling HARD left under braking. I replaced the hydroboost unit, the rotors (both sides), pads, calipers (both sides, and yes I greased the slides and everything) as well as the brakes hoses on both sides. The truck still pulls slightly to the left while braking as well as it seems to drag a little after coming to a stop. I have also inspected all of the hard lines on both sides for kinks and have bled everything until it flowed clear fluid with no bubbles. HELP! ABS pump/module maybe? It's got me confused.
Old 04-07-2014, 04:18 AM
Schurkey Schurkey is offline
Re: 1996 Chevy C2500 Suburban 350 V8 Hydroboost brakes.....truck pulls hard left
How are the rear brakes?
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 04-07-2014, 10:03 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
If it's pulling left, it most always means a problem with the RIGHT side brakes. Obviously, start with caliper, rotor, pads. Then carefully bleed and triple-check all lines - maybe a hard line on the right side got crushed somehow and is restricting fluid flow. If someone has recently done work underneath truck, there's always a chance that they bent/crushed a line inadvertently.
Good luck
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
Old 05-18-2014, 09:44 PM
thzpcs thzpcs is offline
There's 2 separate parts of the master cylinder, one for each side of the car. There could be an issue with the MC, or as others suggested, and issue with the lines on the right side of the car
Old 05-19-2014, 11:46 AM
The master cylinder isn't split for the two sides of the "car". It's split front/rear.
