97 5.7 stalls/stops on starter crank, advice?
97 Suburban 5.7. When starting, engine turns over normally, but every 2 seconds or so the motor will completely and suddenly stop rotating for a split second, then start cranking again. It is as if every few seconds there is a buildup of compression in a cylinder that won't allow it to turn over. It will eventually start and run normally, but i believe this has contributed to going through 3 starters within 20k miles. The starters are free (warranty) but getting tired of putting them in. Any suggestions would be welcome.
-Tucker |
Re: 97 5.7 stalls/stops on starter crank, advice?
| The Following User Says Thank You to rhandwor For This Useful Post: | ||
TuckerK (04-06-2014)
If too close the starter will bind on the flywheel. also this destroys the drive bearing. |
| The Following User Says Thank You to j cAT For This Useful Post: | ||
Thanks guys. I first suspected the starter as well, however I pulled the electronics and cranked it and it did fine, so it is obviously a timing issue. I was ready to test the timing chain as described, but when I pulled the cap, I noticed that it was so worn, some of the contacts had developed little side "slag" bumps on them on the leading side. I now suspect that those are causing an jump/short that causes a BTDC fire intermittently. I will replace the cap, rotor, plus etc... and see if that was the issue.
Thanks for the advice, will keep you posted. -Tucker |
It was the distributor/rotor. The little slag stalagmites that built up on the electrodes cause it to intermittently short, sending a spark far BTDC, stalling the motor. New cap and rotor fixed it.
I'm glad you found the problem.
after a few thousand miles check the rotor/cap. if it is messed up again check that the distributor bearing is not worn , rotor wobble.
