Go Back   Automotive Forums Car Chat > Car Rumors & Concepts
Car Rumors & Concepts Post pictures and discuss the upcoming cars, rumors and spy photos.
Old 04-04-2014, 11:32 AM
niallhm niallhm is offline
twin v8 busa
thinking of coupling two 1300cc hayabusa engines together by connecting them to a limited slip differential where the axel would usually go and then attaching the drive shaft to another diff to power the wheels. can you think of any mechanical problems i might have would an open diff be better? thanks.
Old 09-05-2014, 07:06 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: twin v8 busa
How are you going to get one engine to spin backwards? If you connect each engine to one end of the axle (where the wheels would normally go) one engine will be spinning the diff "forward" and the other "backward". So if using a limited slip you'll destroy the clutches and if using an open diff you'll get virtually no pinion output.
-Rod
Tags
differential , engine , limited , slip , twin
