Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-03-2014, 12:57 PM
bandaidmd bandaidmd is offline
96 5.7 fuel regulator and injector upgrade question
Pulling apart my suburban to put the new style spider in an noticed theres no hose on the nipple of the old regulator, do these old systems just dump fuel into the crankcase? the top of the lower intake was shiny like new directly under where the nipple was pointed. I had the symptoms of a bad regulator but with over 200k just decided to do it all while I was in there. I dont want to put it back together if theres supposed to be a hose somewhere that goes on the regulator.
Old 04-03-2014, 01:55 PM
j cAT j cAT is offline
Re: 96 5.7 fuel regulator and injector upgrade question
I don't have the spec info on your vehicle . a picture would be good showing all this.
question I have to you is how is it that you took this apart and now you ask where do the hoses/lines go ?
a fuel regulator that I am familiar with bolts on the the fuel rail. that is the output to injectors, next is the fuel line feed from pump, and then you have the return line that returns any over/excess fuel back to the fuel tank..
Old 04-03-2014, 02:16 PM
Tech II Tech II is offline
On these engines, the plenum covers the spider assembly/fuel pressure regulator.....there is a vacuum inside the plenum, so there is no need to run a hose to a vac source......the entire top of the lower intake should be blackened/dirty.......if there is a clean spot under the nipple of the f/p reg, it was probably leaking.....
The Following User Says Thank You to Tech II For This Useful Post:
bandaidmd (10-08-2016)
Old 04-03-2014, 04:53 PM
I was just kinda shocked to see the "nipple to nowhere" when i pulled the cover off. Jobs all done now new kit is in just need to change the oil now that i see the crankcase is the overflow receptacle (via cyls 4&6). thanks for the reply
Old 04-03-2014, 05:00 PM
umm thanks I guess for the condescending reply especially since you admit to not being familiar with this vehicle.
I guess while your taking something apart you have never noticed that something "may" be missing.
Old 04-03-2014, 06:12 PM
so what your saying is you have had this operating with a hose disconnected from the fuel regulator . I find that very hard to understand with the fuel regulators on other GM engines I have worked on...
my comments about the dis assembly and your questions on how to put back what you just worked is still quite surprising.
at least you figured it out and got it running . if a connection did fall off there is only one place it can go unless someone put hoses on components in the wrong places.
good luck .
Old 04-03-2014, 06:47 PM
777stickman 777stickman is offline
Tech II's response was exactly what you needed!! Glad you got it figured out.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
