Old 06-26-2003, 06:13 PM
Fewman Fewman is offline
Send a message via AIM to Fewman
Is this what bridging is?
I want to make the best of my sound - I have 2 JBL 500 W subs and one Pioneer GM x314 amp and one MPA 500us Blaupunkt amp.
Would it be best to divide the amps to each of the subs so i get half of each amp working on each sub? I'm VERY new at this so thanks for your help and patience =)
Here are the specs on the amps:
http://www.blaupunktusa.com/pdfs/amps/mpa500.pdf
and
Old 06-27-2003, 09:28 PM
Werdna Werdna is offline
Are the subs dvc? and what are their ohms?
Old 06-28-2003, 12:12 AM
b16a3sol b16a3sol is offline
what you need to do is figure out which amp makes the power that most closely resembles what the subs can handle. neither of these amps will be able to power one of those subs the way they should be, unless that rating is max power, and not RMS. the closest you will be able to get is to wire just one sub to the blaupunkt amp, as long as the sub is SVC and rated at 4 ohms.
that pic you posted is for a 4-channel amp that will not make enough power to put even one of those subs to good use. use that amp to power your cabin speakers.
this is a rather mismatched setup you have going here. before your next purchase, try and figure out what you are going for and get items that have relatively similar power ratings. if you keep doing what you are now, you will always have something that you wasted money on, because it is not being used at its full potential.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 06-28-2003, 12:16 PM
The system actually came with the car. I just want to put it to best use =). Is there a way to use the amps on only the subs? I don't really want to wire them to the front... I'm too inexperienced, perhaps I could be enlightend though on how to run them through the doors? Thanks
Old 06-28-2003, 12:45 PM
AirAllen01's Avatar
AirAllen01 AirAllen01 is offline
Send a message via Yahoo to AirAllen01
Are the subs 500 watts Max, or RMS?
Have you ever danced with the Devil in the pale moon light?
I'm your Huckleberry.
Don't hate the playa, hate the game.
Unreal Tournament 2004 Mexican Mafia «MM»Sternum
Visit AF's Sketching and Drawing Forum.
http://www.automotiveforums.com/vbulletin/f1155/
Old 06-28-2003, 01:08 PM
I have no idea - this is just what the guy told me. It handles the 500 W amp hooked up to it fine, and sounds really great...
Old 06-28-2003, 06:28 PM
look on the back of the subs and see what they say. at least get the model number and look up the specs on the net.
Is this what I think it is...Diablo 302 V8 engine? SemiAverage711 Diablo 6 12-12-2008 01:40 PM
what is this and why is it like this? BLU CIVIC '88 - '91 Civic | CRX | Wagon | Shuttlee 3 07-21-2008 09:57 PM
I am tired of this WHAT YEAR IS THIS CAR?! PseudoKirby Elantra | Avante 1 08-25-2006 10:58 AM
ck out this site, i know this guy from st.pete fl. he realy know what he is doing. CBURKE '88 - '91 Civic | CRX | Wagon | Shuttlee 18 01-14-2005 09:07 AM
This is what happens is you try to cheat!!! Neutrino COMPLETELY off-topic 0 01-04-2004 06:57 AM
