Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-30-2014, 04:55 AM
DiBo DiBo is offline
Grinding noise while turning
Folks I have a '96 Cutlass Supreme, V6 3.1. Recently when I turn hard to the left I hear a grinding noise coming from the front drivers side... The noise only happens when I make a hard left... A slight left turn the noise does not appear. Turning right no noise is heard...
Any ideas what would cause this?
Thanks!
Old 03-30-2014, 10:00 AM
Tech II Tech II is offline
Re: Grinding noise while turning
Exactly what is a hard turn compared to a normal turn to the left? Is this at low speed or high speed on the hard turn?
Is this a rotational noise? Does it get louder with speed?
So if you are driving down the road on a highway, and you move to the left lane is there a noise....if you move to the right lane, there is no noise?
Old 03-30-2014, 09:24 PM
I hear the noise when I crank the steering wheel to parallel park... I do not hear it at all while driving straight, I only hear it when I have to make a sharp turn to the left
When driving down the road and move to the left lane, I don't hear the grinding noise at all...
I do not hear the noise while driving only turning left...
Thanks !
Old 03-30-2014, 10:05 PM
Check the dust shield on the LF brake caliper, if it is bent too close to the rotor...
Any recent brake or front end work? Hit any pot holes lately?
Old 03-31-2014, 05:02 AM
dharris973303 dharris973303 is offline
if it does it on the all the way over on the left, does it do it all the way over on the right?
to inspec t it yerself ya gotta get it up. or turn the tires.
if ya made the nose recently and there's a tire rub it should be easy to spot. check the inner tire walls, the fenders, and lowercontrol arms.
is it a rubbing noise or metal to metal? metal to metal get the tire in the air and check the berring, (top and bottom lateral movement)
if this is out of your relm, have a shop, many have free inspections, right before they sell you somthing
Old 03-31-2014, 10:25 AM
Dharris' post reminded me it could be something as simple as a loose mud flap.....if you have them on your car...
Old 03-31-2014, 02:42 PM
rkvons's Avatar
rkvons rkvons is offline
I diagnosed a car that was making a grinding noise once. It turned out that the spring of the strut broke and the broken spring was touching the tire.
Old 08-18-2014, 07:40 PM
Bublong Bublong is offline
Hope you've discovered the problem and have been able to fix the issue. I recently had this issue on my 92 cutlass and it turned out to be the steering gear was shot and needed to be replaced.
Old 02-06-2015, 12:44 AM
jinxyzboi jinxyzboi is offline
If you have a "grind" on the wheel it's only 2 culprits either the hub bearing is bad or more likely it's going to be a CV joint problem. Unless you have something stuck in there. You can visually check the CV boot. If it is ripped thats going to be the problem, or if not will soon be. CV joints hate even dust let alone dirt.
