Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-27-2014, 09:38 PM
makuloco2000 makuloco2000 is offline
Alternator Not Charging 2011+ Here's Why
Just wanted to pass this info along as some may be experiencing perceived weak batteries or just want to do the occasional checkup before a long road trip and bam you find the alternator is not charging, don't worry just yet here is why....
The Following User Says Thank You to makuloco2000 For This Useful Post:
shorod (03-28-2014)
Old 03-28-2014, 07:07 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Alternator Not Charging 2011+ Here's Why
Very interesting! I just changed the battery on my 2011 SHO about a month ago. I'll have to connect my DS708 and see if I can reset the battery age with that. Hopefully, if not, the system will eventually accommodate the new battery.
-Rod
Old 03-29-2014, 07:12 AM
-Rod
I don't know of any scan tools that will clear the age besides the Ford scan tool. It will accommodate it eventually but it is best to reset the age as it is a major factor in the algorithm it uses to charge it at an optimal rate. Just like the pcm has algorithms to compensate for vehicle aging in the powertrain system.
Old 03-29-2014, 07:22 AM
If the vehicle battery is replaced, carry out the Battery Monitoring System Reset using the scan tool. If the Battery Monitoring System Reset is not carried out, measurement data collected for the old battery is not deleted and future state of charge measurements will be inaccurate. For example, if an old battery has a state of charge of 60% and the new battery has a state of charge of 90%, the BCM will recognize battery state of charge being 30% lower than it actually is. With the battery state of charge being perceived lower than it actually is causes shedding of loads earlier than is necessary. This also impacts the smart regenerative charge system by causing the battery to be maintained at a higher state of charge than perceived by the BCM, reducing fuel economy benefits.
Old 03-29-2014, 09:00 AM
Here is the original Alternator Load Testing video that I refer to that is still the most accurate test even on these new charging systems.
