Hi, does anyone know the actual name of the plug under the steering wheel that you plug an OBD-II scanner into to get the service engine codes? Mine is missing pins and doesn't read any more. I need to get a new one. Thanks.
Re: Scanner plug?
what year what model?
Lot of plugs don't have all the pins. Are you sure your reader is any good? Have you tested it on another vehicle?
Post back, that's what makes Forums Work. |
Re: Scanner plug?
2002 Dodge Ram 1500 4x4. Yes, the scanner works on other cars. My plug is cracked and missing pins. It needs to be replaced. Do you know the official name of this part?
Re: Scanner plug?
I've heard it called OBD port or diagnostic port.
Re: Scanner plug?
DLC it stands for Data Link Connector.
http://www.carplugs.com/products.html |
Re: Scanner plug?
Or even ALDL, Assembly Line Diagnostic Port.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
