Old 06-26-2003, 03:58 AM
syn0s syn0s is offline
Angry noob question: My car gets NO Power!! HELP
OK here goes. I'm new to this board so be gentle. I got a 94 Civic EX Coupe (D16Z6 engine). I was cleaning my engine bay with some gunk Engine Brite, and I covered up the distributor and air intake and electrical components and stuff, then sprayed the engine down. I let it dry off, then tried to start it and NOTHING. No Power, No Sounds... Nothing when the key is turned. Is it something with the ignition or is it electrical? Someone please help me! What did I do? Any ideas?
Old 06-26-2003, 04:05 AM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
Sounds like electrical to me. Make sure the battery stuff is all hooked up and tight.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 06-26-2003, 12:53 PM
Egg_Shen's Avatar
Egg_Shen Egg_Shen is offline
Re: noob question: My car gets NO Power!! HELP
OWNED by cleaning the engine
but really I was going to do the same thing to make things under the hood pretty, but decided I didn't have time last week... maybe I won't do it I got the engine cleaning spray on foam(smells like paint thiner)
Old 06-27-2003, 11:05 PM
Any Ideas?
Anybody? Any ideas? I need to get my car fixed - moving out of my house in 2 weeks! Please...help.... me.
Old 06-27-2003, 11:29 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
check your battery posts, 1 if the cables are attached and 2 that they are not covered in that white shit that gets on em. scrape that stuff off so your + and - wires have a good connection.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-28-2003, 01:37 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
syn0s--does your dash borad lights up when you turn the key to the first click?
check to see if you have water inside your distributor cap?
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 06-29-2003, 09:19 PM
nope
Tofuboy - That's a big negative. When I turn the key.. Absolutely nothing happens. No lights on the dashboard... No electrical systems (you can't hear em start up).. Nothing. Very Strange. Thinkin its the fuse, battery or water got in the distributor. Any other ideas? Thanks a ton guys.
Old 06-30-2003, 01:22 AM
funkdaflex1 funkdaflex1 is offline
pop your hood let it sit in the sunlight for a couple hours?????? try and dry some things up.
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 06-30-2003, 01:44 AM
Tofuboy's Avatar
syn0s--Did you disconnect the battery cable before you start spraying water or engine cleaner in the engine bay?
If so, did you reconnnect the battery terminals?
If you did not disconnect the battery cable, I afraid you may have fried some electrical systems.
Do you have a volt meter to check to see if the battery has somewhere about 12.6V?
95 Civic EX
83 Toyota Starlet
Old 06-30-2003, 04:20 AM
Its not really important to do that. You can pour tons of water over a hooked up battery and nothing will happen. I've washed MANY cars engines over the years , nothing has ever happened. I'd say its more likely something became disconnected.
Old 06-30-2003, 08:54 PM
Gerbilo Gerbilo is offline
Send a message via AIM to Gerbilo
we had a problem with this on a jeep when offroadin, water in the distributor cap, dried up after a few minutes though.
Old 07-01-2003, 04:13 AM
Most serious off-roaders spray their caps with WD40. WD40 displaces water , and is pretty much inert , so it won't catch fire. I learned that trick long ago , from driving old Fords thru deep puddles........
Old 07-02-2003, 09:49 PM
yeah, i don't think he was planning on going thru that deep of water, but we egged him on, it was fun tryin to work on it in a huge puddle/pond because no one felt like hookin up the tow straps lol.
Old 07-03-2003, 07:02 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
I used to do car detailing, and of course cleaning engine bay's is part of that. I'd say most likely you got water inside of the distributor cap. You can try taking it apart and letting it dry out.
Old 07-03-2003, 10:02 AM
crxlvr's Avatar
so is this problem been solved yet or what?
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
my 99 alero fuel pump is not getting power help please? 210alero Alero 5 02-10-2010 10:51 AM
