Old 06-26-2003, 12:59 AM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
Dremmil
do you guys use a dremmil? i notice alot of people cut out for their exhausts and it looks all choppy, it wouldent be a bad idea to invest in some sort of rotary cutting/sanding tool. thats IMO
Darrell
thegrumpysergeant.net
Old 06-26-2003, 01:01 AM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
dremils rock
i dremiled my race bike, so i could fit bigger bearings in the cranks
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 06-26-2003, 01:13 AM
TURBOSATURN's Avatar
TURBOSATURN TURBOSATURN is offline
I use a dremmel, you would be suprised how much time it saves!
Old 06-26-2003, 01:15 AM
Jetts's Avatar
yea they are very quick compared to try doin shit with your hand
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Old 06-26-2003, 01:58 AM
simdel1's Avatar
simdel1 simdel1 is offline
i dont have dremel, but i do have a cheaper version....does the job just as well....
Simon
Old 06-26-2003, 02:11 AM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Whut kind do u use? Wondering, want to get a cheaper version of Dremel cuz its to much.
Old 06-26-2003, 02:16 AM
Mr B Mr B is offline
my dremel is the best money i have spent. can use it to fine sand, chop and cut anything from metal to plastic. i would recommend one for sure.
cheers B
Old 06-26-2003, 02:47 AM
Personaly i would recomend the dremmel, because it comes with a 5 year warranty and i have the one that has the variable speed, but if your not willing to spend that much, check out your local, walmart or parts store, and you could pick one up for like 20usd.
Old 06-26-2003, 07:34 AM
simdel1's Avatar
its called a ''como drill'' i dont even know if its still being made. i got it about 5 years ago for christmas (i liked to drill holes in things as a kid ) it cost about £30 with a few tools. the one i have has interchangeable chucks so it can even use the tools sold for the dremels
i agree with TURBOSATURN that the dremel would be better because it has a good warranty, but unless you are making hundereds of models, i think a cheaper ''mini drill'' will do the job just fine.
wall mart, or some catalogue store will probably have one.
Simon
Old 06-26-2003, 07:37 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
I own a dremel, and I don't use it to do all that much so often anymore, it spins too fast, even on the lowest setting!
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 06-26-2003, 08:21 AM
Jonno
i solved the problem of the dremel spinning too fast by making a speed controller out of a light dimmer switch.it's all done safely, 3 pin plug into an electrical box, thru the dimmer switch and into the 3 pin socket. it looks just like an extension cord but with a box in the middle. i just plug the dremel into this and i can vary the speed from about 200rpm upto 37000 rpm. cost me about $30 but now i can use it for everything.
cheers B
would have pm you but thought others might find this usefull.
Old 06-26-2003, 08:26 AM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
i own a Dremel, but i dont use it as much as i should
Rui
(modeling) = Click Here
Old 06-26-2003, 10:39 AM
SuperStreet reader's Avatar
SuperStreet reader SuperStreet reader is offline
Send a message via AIM to SuperStreet reader
I wanna dremel
--TONY--
Old 06-26-2003, 10:50 AM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
cheers B
I have a dremel too, BUT i do'nt know how to FINE sand with it.. the finest i have is like 150 grit
Old 06-26-2003, 12:03 PM
AF's #1 Bad Guy
check out autozone or shucks it has its own brand and they make a pretty good one for like $20 with like 50 pieces with it
Darrell
Tca tool storage Tcatoolstorage General Tools 0 05-26-2010 10:35 PM
obd2 plug scan tool will not connect sdime9484 Problem Diagnosis 1 01-01-2010 11:49 AM
Is General Motors - Chevrolet going Bankrupt? Zaara Spark 2 06-01-2009 05:57 AM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
