Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 03-25-2014, 07:19 PM
bbenavitz bbenavitz is offline
Do I need to upgrade brakes?
Updating to an LS3 motor (480 HP) in a GTWC (chassis #13) which still has a stock 4.6 4 cam that has about 320 HP. For those who have 400 plus HP motors can you give me advise on what I can expect with the stock brake set up?
Old 03-26-2014, 06:44 AM
cvbowers's Avatar
cvbowers cvbowers is offline
Re: Do I need to upgrade brakes?
What is the current brake set up on the car you have? If it is the PFC rotors with the big Brembo Brake Kit, then I think you are probably good to go. These brakes are pretty robust. You might need to change the pads to a little more aggressive set up. My car had the PFC 97 Enduro Pads. They did not have enough initial bite.
CVBPackman
Charlie
Old 03-26-2014, 03:09 PM
Yes, I have the Performance Friction 12.91" x 1.25" rotor (friction ring) with Brembo F50 calipers on all corners. Yes, I am not happy with the initial bite on the pads I have now.
Old 03-26-2014, 04:20 PM
cvbowers's Avatar
My experience is that the rotors and brake calipers are more than sufficient. Experiment with some different pad compounds and find one that meets your needs. The engine I had before the LS1 swap was a built Ford 347 stroker making just under 400 wheel hp. Braking was never an issue.
CVBPackman
Charlie
Old 03-26-2014, 06:35 PM
Any tips from your LS swap?
Old 03-27-2014, 06:44 AM
cvbowers's Avatar
My son did 95% of the work. You can review the entire build on this forum. The thread is posted by Cobra4B. He did a fantastic job.
CVBPackman
Charlie
