Old 06-25-2003, 09:14 PM
MattyO217 MattyO217 is offline
Pro/Cons of painting brakes?
I'm considering painting my rotor hats (brembo blanks) with high tempature (1500F) paint. Has anyone done this? Does anyone know the advantages and disadvantages of doing so? I am considering painting them gray just for looks to prevent rusty rotor hats.
Thanks,
M
Old 06-25-2003, 11:14 PM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
Use HIGH temperature paint , at least 1500 degrees.Brakes can get just as hot as an exhaust header . And make sure none gets on the braking surface itself.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 06-26-2003, 02:19 AM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
it shouldnt do anything there shouldnt be any cons and one pro you can have it match your car for a lil bit of show
MODS: Motor :jdm b16 block, itr head, skunk 2 cam gears, msd ignition, intake, exhaust, straight pipe, skunk 2 ecu. act race clutch Suspension : grnd cntrl coilovers, 4 way adj shocks , spoon strut bar, skunk 2 sway bar, itr control arms, energy bushings misc. : super nice jdm seats, momo detachable steering wheel, Jdm clutster, Spoon Cf duckbill wing, vision smoked amber turn signals. COMING VERY SOON IN DAYS LS vtec ARP ROD BOLTS HEAD BOLTS AND 75 SHOT OF GIGLE JUICE look in my galler
Old 10-19-2003, 09:42 PM
cwoblong cwoblong is offline
Re: Pro/Cons of painting brakes?
Paint holds heat in longer.
Old 10-20-2003, 01:08 AM
BullShifter's Avatar
Re: Re: Pro/Cons of painting brakes?
Paint it if you want, just dont it get on the surface as stated above. Paint your calipers to match while your at, just dont get any on the rubber seals.
You could sand the rust off, but its likely to come back. After you do whatever you do, spray the wheel mating surface with white lithium so the wheel doesn't stick it the rotors, peeling paint away next time you remove it.
the pros/cons mr92accord Forced Induction 15 02-27-2003 06:50 AM
18"s on a 93 accord pros/cons? ogre Tires and Wheels 1 02-22-2003 11:00 PM
Which wheels? 15's or 16's Pros / Cons of each? LX98Civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 09-11-2002 01:18 PM
What exactly is an MP3 player? Pros / Cons needed! LX98Civic Car Audio 5 06-12-2002 04:02 PM
Pros/Cons of removing a converter 4u2envy_accord Accord/TSX/Accord Hybrid 15 12-30-2001 05:13 AM
