Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 06-25-2003, 06:07 PM
Farmer Jim Farmer Jim is offline
Mercury keyless entry
I need to program a new remote control to my 1995 Mercury Grand Marquis keyless entry system.
I have been unable to find directions for doing so.
I will appreciate any info. on the steps for programming.
Old 04-18-2004, 07:20 AM
keyless keyless is offline
Re: Mercury keyless entry
I have a 99, just turn the ignition on to off 4xs, after the 4th time leave it on . Your door locks should lock and unlock. Once this happens just press the desired remote key and it should respond.
Old 04-18-2004, 11:03 PM
thepartsyouneed's Avatar
thepartsyouneed thepartsyouneed is offline
Banned
These instructions will work on Ford Crown Victoria / Mercury Grand Marquis models 93 94:
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located behind the glove box. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
These instructions will work on Ford Crown Victoria / Mercury Grand Marquis models 95 96 97:
Enter 5 digit permanent entry code into the keyless entry keypad. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter within 5 seconds of pressing the 1/2 button. Locks will cycle to indicate successful programming. Press any button on 2nd transmitter (up to 4 transmitters total possible) within 5 seconds of previous transmitter. (if the keypad light goes out before all transmitters are programmed, the entire process must be repeated). Press the 7/8 and 9/0 buttons simultaneously on keypad to exit programming mode.
These instructions will work on Ford Crown Victoria / Mercury Grand Marquis models 98 +:
Diagnostic method of programming transmitters:
1. Choose service bay functions from the service function card.
2. Choose DDM (Driver Door Module)
3. Choose Key Fob Programming
4. Press any button on the remote entry transmitter
5. Choose Fob 1, 2, 3, or 4 and press STORE
6. Repeat steps 4 and 5 for additional transmitters
7. Press Cancel to get out of menu
Note: If transmitters do not appear to be working after procedure is complete, disconnect the vehicle battery for 5 minutes, then reconnect and try the transmitter again.
Old 04-24-2004, 09:19 PM
Angry Illuminated keyless pad does not work
I have a 1999 Mercuty GM. My remote keypads stopped working.
After several attempts to reprogram them I just disconnected the battery, let things drain and reconnected the battery. once complete everything worked fine , even my drivers side window control. I now have one problem left:My illuminated keyless entry pad on the drivers side door no longer accepts the factory default code. The code is posted in the trumk, but if I Iattempt to use it it does not respond in any way. Any ideas on how to set that to the default without going to the dealer (79.99 just to connect it to the computer). Thanks, you guys have been great!
Old 01-13-2006, 07:36 PM
eaverill eaverill is offline
Re: Re: Mercury keyless entry
My remote stopped working yesterday and I wanted to try to fix it. I have a 94. I looked behind the glove box, and there is a blue box, do you know if that is what I am looking for? Also, what wires do I 'jump', how is this 'jumping' carried out and how do I get the wires out of the blue box?
Old 12-28-2011, 12:34 PM
kyle715 kyle715 is offline
Any luck on programming the remote? I can't figure it out
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
