Old 03-20-2014, 09:48 AM
nsnivs nsnivs is offline
Remote Switch/Amplifier Help
Can someone please give instructions on installing remote toggle switch. I am using the stock radio so where do I get the power from and what wires do I use to connect to the switch. Also, when I turn car off my subwoofer lets out a loud blare that will not stop I have to pull the power supply to stop can someone please tell me why and how I can fix that as well thanks.
Old 03-20-2014, 01:15 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Remote Switch/Amplifier Help
find a wire in the dash that has 12V only when the car is on. Run that into a switch and the other side of the switch run a wire from there to the amp terminal ore where it says Rem or Rem turn on or w/e. Turn the amp off BEFORE you turn the radio or car off, should prevent the blaring.
Old 03-20-2014, 02:26 PM
Well I just blew my speaker when I turned the car on the sub just started blowing like crazy. Anyway as far as the remote switch for the power can it be powered by an empty fuse location?
Old 03-21-2014, 08:16 AM
Audio Guy
yes ...
It sounds like you have the remote terminal wired directly to the +12V terminal on the amp
Old 03-21-2014, 11:13 AM
The remote wire is just going from the remote terminal run through the car by the fuse box where I was trying to use a fuse for the switch. The rem wire wasn't ran to the 12v of the amp. I don't know I can't figure out why it just blasts like that when the car is turned on I may just have to take it somewhere and pay someone I was trying to save the cash
Old 03-24-2014, 08:23 AM
Audio Guy
what is the gain on the amp set too ?
Old 03-24-2014, 04:59 PM
I can't remember now I returned my amp. This is the speaker I had http://www.polkaudio.com/products/db1212 and the amp was Alpine MRV-M500.
Old 03-25-2014, 03:13 PM
Audio Guy
always turn the gain all the way down (counter clockwise) before turning it on the first time.
Tags
amplifier , remote , subwoofer , switch , wiring
