Old 06-25-2003, 04:31 PM
flyguy86 flyguy86 is offline
Send a message via AIM to flyguy86
white face gauges
I was looking on ebay and i found some but they only have years 93-96 then 2000+. The 93-96 have the analog odometer and the 2000+ have the digital. i have the 97 and i have the digital. i was lookin at my stock gauges and everything looks the same except the styling of the numbers (different shape like a diff font). would the 2000+ gauges fit in my 97 firebird??
Old 06-26-2003, 11:59 AM
any ideas? i wanna get these but i dont want to order them and have them not fit.
Old 06-27-2003, 10:35 AM
could i make it fit?
Old 06-27-2003, 01:32 PM
99' Z-28's Avatar
99' Z-28 99' Z-28 is offline
i wish i could help. i know how you feel. I'll try asking around. My guess is wont fit. I doubt it would fit because in 1998 Firebirds and Camaros had some changes done to them in the inside. I don't want to tell you wrong or anything, but i'm affraid they will not work. You could get them and try if they don't work you can send them back.
AF User Guidelines
-Exhaust Man
-Race Car Driver
Old 06-28-2003, 04:32 PM
what about the 96. Have u seen firebirds with the white faced gauges?
Old 07-01-2003, 07:07 PM
senaclinton's Avatar
senaclinton senaclinton is offline
ok, i know i pm'ed ya, but i found another...not sure if it will work...
http://www.custolight.com/id21.html
http://www.suncoastcreations.com/parts_auto_93-97_firebird_interior.htm
just overlays i think...
hope it helps
-sena
Old 07-15-2003, 04:16 PM
First Lady First Lady is offline
they have lots of different gauges at www.procarparts.com
I bought mine there and they are a perfect fit
Nicole
Illicit Dreamz Car Club
Race & Offroad Design, LLC
Salt Lake City, UT
Old 07-16-2003, 12:29 AM
yea but you have the 2002 i need the 97-98 model gauges. I emailed them and they said they dont make them.
Old 07-16-2003, 12:59 PM
if yours is a V6 http://www.custolight.com/id21.html
the description on procarparts says 93-97
http://www.procarparts.com/store/dis...3FBD110-SILREV
Pontiac didn't make major changes between 96 and 97. The 93-96 should be the same as the 97 anyways and procarparts is good about returns, just as long as you try it out the day you get it. If you have any problems, ask to talk to Leo there, he's very helpful (do not talk to Daren)
Old 07-16-2003, 02:50 PM
there was a differnece. The 96 had the rolling number odometer and the 97 had the digital odometer thats where i run into the problem.
Old 07-16-2003, 03:03 PM
mine (i know its a different year) just had a square hole where the odo shows thru. the guages just lay over the stocks and has cutouts where the airbag and check guages lights are. all i had to do is take off the bezel and lay the plastic sheet over the old guages, using the same needles and everything. is the hole for the odo in the same place as yours? its worth a shot...
Nicole
Salt Lake City, UT
Old 07-16-2003, 04:58 PM
how do u get over the needles, how does it stay in place is it hard to wire up?
Old 07-16-2003, 05:29 PM
theres a hole where the center of the needle goes and you just turn them all to the left and thread the needle through, just don't break them. You can glue it down but the bexel held mine right in place. As or wiring, you screw the switch in somewhere (I put it in under the trunk popper where the screws are that hold the dash up) and a wire goes to your fuse box. Just upgrade the voltage of the fuse so you dont blow it (if you take out a 15, put in a 25). Very easy. The hardest part was finding the little spring-loaded trip reset knob that sprung out when I took the dash apart! They're not stickers or anything either, its thick enough plastic that you can't see the stock red lights (that you dont have to disconnect) only the blue.
come check out www.pontiacfirebird.com and ask some people in those forums, too, they're awfully smart!
Old 07-17-2003, 12:54 AM
thanks. How long did it take you to install them
could u just wire it to the headlight fuse and turn down the brightness?
Old 07-17-2003, 11:08 AM
seriously, it took like 20 minutes! i took a second to maneuver the whole gauge pod thing over the steering wheel but other that that, it was easy.
if i remember correctly, the headlight fuse in my car is in the engine compartment so it was easier to wire it to one of the fuses in the box in the side of the dash. I got the silver reverse glow ones and it has a dimmer knob (that I screwed into the bottom of the dash) and a green/ blue switch
i think theyre like 20 bucks now and that one does say 97 in the description so you could always return them if they dont work
i wouldnt get the stickers, though, the ones that you print or whatever...
indeglo gauges/dash cluster over lay/ white face gauges justgetingstarte Explorer | Explorer Sport Trac 0 04-06-2006 04:47 PM
white face gauges g20jojit Cosmetics 16 03-29-2002 09:32 AM
White Face Gauges For G4 Prelude Prelude Racer Prelude 1 08-06-2001 01:21 PM
WHITE FACE GAUGES for P10 ishydaflip Cosmetics 5 06-29-2001 04:12 AM
