99 Tahoe start then cuts off and on
Today my 99 Tahoe 5.7 150K miles starts fine after 2 minutes it starts to shut off and back on then runs smooth and then cuts out again. It almost seems like the engine stops all the dash light go on then kicks in again. I all so notice the tach moves all over the place (0-1200 rpms). Fuel psi 62 checked the MAF, Coil, ICM and new Distributor 2 months ago. Looking for ideas here this one is a head scratcher and it all started as I was driving home.
Re: 99 Tahoe start then cuts off and on
Thanks j Cat you have helped me out in the past. I will check that tonight. I did notice that the Tach bounces violently up and down as the engines seem to turn off and on. The Tach does not move the same as if you had a rough idle or misfire. The more I think about it all the warning lights come on as it almost stalls.
| The Following User Says Thank You to j cAT For This Useful Post: | ||
chris peter (03-23-2014)
Update on problem I watched my dash lights and radio to see if the lights went out and they stayed on so I was puzzled maybe not the ignition switch. Next I rechecked all my voltages (ignition, maf, coil ) all checked good including the grounds. Finally I let the truck run until it shut off its self and this time it set a code P0339 crank sensor intermittent signal. Replaced the sensor problem solved. This crank sensor was only 2 years old so I did not suspect it to be bad. I purchased the sensor at AutoZone so the duralast warranty paid for the new one but now I think I should purchased a OEM sensor instead. Time will tell.
I have had trouble with these usually after they heat up they then internally open and the engine will just stop. then after a few hours it start up fine.. good to report back ..this being intermittent you got lucky.. |
