steering issuses
hello everyone im sure this has been ask before im new to the site so I figure I just start a new post I have a 97 1500 my steering was messing up so I replace the pump the valve on the back of the pump and it still feels like I have no power steering at low speeds or when I first take off and try to turn the wheel I was reading about the evo on the steering shaft I disconnected it today my question is after I unplugged if it was bad how much better should it be I got better its now has hard to turn at low speed like it was and next question I have is it normal for when you turn the key on not to start just on the on postion and try to turn the wheels they wont turn any help be great thank you
Re: steering issuses
could be bad pump many have had to replace the steering box. when worn the bind. |
is they anyway to test the steering box to is if its bad before spending the $175 for anew one and I already bleed the power steering pump and all
sometimes you get hard steer to right or just sloppy steering. replace the pump again. make sure the belt is clean not slipping no oil on it or the pulleys ..if you get no pressure then it is the pump ...this happens very often..new pumps n/g. |
I jacked the truck up today and found out that my upper ball joint on the driver side is shot so would that cause my hard steering when turning to the left
how often do you grease these ? you have a shop do this greasing ? |
I think I found my problem I can move my steering shaft in and out of my steering box guess it time truck has 262,000 miles on it
reason is the rebuilt ones are crap. Last edited by j cAT; 03-26-2014 at 09:32 AM. |
guess I be calling around here to see if any of them has one plus have to pull the lower control arms off anyways to take them to the shop just put new upper ball joints in have to put the lower ones in
not to hard to replace the steering box I got a used one from my salvage yard the truck 80,000 miles on it to remove the box the 3 bolts on the frame the 2 lines the pitman arm and steering shaft right
how does it steer ?
its steers awhole lot better with the new steering box just have to get the new tie rod ends next paid day
like I said the box is a problem with hard steering in most cases but you do have to check out the steering components...also keep it greased so it has to work less..
I just grease all the ball joints and the tie rod ends and all also think im going to get the power steering bypass tube for the EVO on the back of the pump
