Old 06-25-2003, 09:18 AM
Kaiser's Avatar
Kaiser Kaiser is offline
LS/VTEC Don't Believe the Hype.
LS VTEC Don't Believe the Hype. Part 1 of 2 part series.
by Josh Nolff
(2ndGenTeg: HondaStyle.com Moderator)"
If it was all that great, Honda would have done it in the first place. Submitted for your approval, my thesis on why LS/VTEC is a bad idea.
Part 1 covers
What is LS/VTEC?
Why would Honda do that?
What is R/S?
Why a low R/S is bad for reliability
What is power, exactly, and how do Hondas make it?
B Series, by the numbers
How VTEC works, and why it lives at high RPMs
Why it doesn't all fit together
Sources/Influences
What is LS/VTEC?
A quick tutorial for anyone who doesn't already know.
LS/VTEC is using a B18A or B18B block (referred to as an LS block, even though it was found in the RS, LS, and GS) and mating it with any of the DOHC VTEC heads- the B16A, B17A, or B18C. The principle is to use the larger displacement of the LS block (READ: higher torque) and mate it with the high end power of VTEC. I'm also sure you've heard of CR-VTEC, which is a very similar idea. It uses the B20Z block of the CR-V (NOT the B20A of the Prelude Si, for reasons that will become obvious later) to achieve the same effect, only on a grander scale. What you end up with is an engine commonly referred to as a "Frankenstein" setup, and it's all the rage these days
So why in the world would Honda put us in such a situation- having to build these incredible motors all by ourselves? Why would they knowingly decrease displacement and torque in a car being manufactured to be faster than its lower-trimmed breathen?
Look at it, too, from a manufacturing standpoint- Honda is already making the higher displacement B18A and B blocks (blocks are identical, only difference was in the head), so why go to the extra time and expense of developing and manufacturing a separate block, especially if it will decrease output?
The answer is easy: R/S.
What is R/S?
R/S is the abbreviation for rod to stroke ratio. It is the ratio of the length of the connecting rod to the length of the piston stroke, or the distance the piston travels from the top to the bottom of its stroke. As the ratio gets lower, the amount of stress on engine internals increases exponentially, killing long-term reliability. The higher the number is, the slower the piston is traveling, killing power output.
The ideal R/S is 1.75:1 (Three cheers for the B16A, at a near-perfect 1.74:1!).
A low R/S means the rod will be closer to a horizontal angle on its upstroke. This means that more of its force will be pushing the piston horizontally, rather than vertically. What does this mean for your engine? Two things.
1. There will be more stress on the sides and in the center of the rod, rather than on its ends, leaving the rod more vulnerable to breaking. Picture a straw. This is no special straw, just an ordinary drinking straw. Is it going to be easier to bend this straw by applying pressure onto its ends, or at its center? Now think of your poor connecting rods..
2. There will be more stress on your cylinder walls. Once again, the rod is pushing the piston at a more horizontal angle- right into your cylinder walls, rather than up and through them. The risk here is double: A. Putting that piston right through the cylinder wall. B. The cylinder wall will actually flex under the pressure, causing the shape to turn from a circle to an oval or oblong shape. This causes the loss of the seal created by the piston rings. What happens? A small amount of oil could slip past into the combustion chamber. Bad things happen from here: The oil gets combusted, leaving nasty carbon deposits in your combustion chamber and exhaust ports- not a good thing for flow or valve sealing.
It's also important to note that as the RPMs increase, so does the amount of stress on your engine's internals.
Warning: Once you see this, you will never look at horsepower and torque readings the same again, especially after you think about it.
P= (TR)/5252
P= power, in horsepower
T= torque, measured in lb/ft
R= Engine speed, in RPMs
Therefore:
Horsepower= (torque x RPMs) / 5252
Try it- pull out a dyno and see what you get.
So from this, we can conclude that if we increase torque or engine speed, we will get more power, right?
Remember that, it's important...
Now how do Hondas make power? Our tiny little 1.6-1.8L engines aren't exactly oozing spare displacement and creating gobs of torque, are they? Hondas make power through revving, and revving high. So why does everyone place so much emphasis on creating torque? It's because all these bolt-ons you see advertised won't raise your redline, but they will increase torque. There's nothing wrong with squeezing every last ounce of torque out of your engine- you should. But trying to get torque from more displacement in a Honda is like trying to fill a swimming pool using a squirt gun. You'll never get enough for it to be useful.
LS VTEC Don't Believe the Hype. Part 2 of 2 part series.
by Josh Nolff
Continuation of Josh's article on "LS VTEC Don't Believe the Hype".
Sources/Influences
Let's take a closer look at the B series engine blocks.
In the B18 blocks, Honda increases displacement by using a larger crank and increasing stroke (the B20Z also has a slightly larger bore, which is bad for reasons I won't go into here). This, of course, lowers the R/S, since the rod length remains (almost) the same.
B16A:
Rod length: 134 mm
Stroke: 77 mm
R/S: 1.74:1
Displacement: 1587.12 cc
B17A:
rod length: 131.87 mm
Stroke: 81.4 mm
R/S: 1.62:1
Displacement: 1677.81 cc
B18A-B; B20B-Z:
Rod length: 137mm
Stroke: 89mm
R/S: 1.54:1
Displacement: 1834.47 cc
B18C:
Rod length: 137.9 mm
Stroke: 87.2 mm
R/S: 1.58:1
Displacement: 1797.36 cc
B20A (Older Prelude Si)
Rod length: 141.7-142.75 mm
Stroke: 95 mm
R/S: 1.49-1.50:1
Displacement: 1958.14-2056.03 cc
Now you see two things: Why the B20A is widely regarded as a not-so-great engine, and why Honda decreased the displacement from the B18A-B to the B18C. Honda decreased the displacement in the B18C by decreasing the stroke, improving the R/S. This allows the B18C to rev higher, and (Hey!) increase output.
Making sense? I bet you can see where this is going. But wait, there's plenty more...
A quick crash course for anyone unfamiliar with VTEC:
VTEC stands for Variable Valve Timing and Electronic Lift Control. The premise is that at low RPMs and at idle, a less aggressive cam grind is necessary to prevent "loping." Ever hear a pro drag car staging up at the gates? Sounds like it's about to stall. It's because he's running aggressive camshafts, and since the cam is spinning more slowly at idle, the intake valve is still open after combustion has completed. That's what causes loping. At higher RPMs, a more aggressive grind is desirable. The idea is that you want to cram as much air and fuel mixture (A/F) into that combustion chamber as possible, so that when it's ignited you get as grandiose an explosion as possible. So what is good at low RPMs is bad for high RPMs. So what do you do?
If you're Honda, you invent VTEC. What VTEC does is simply to employ different cam grinds at different RPMs. A less aggressive grind at low RPMs for a smooth idle and low to mid range power, and a more aggressive grind up high to produce that high end pop. At a strategically placed "VTEC crossover point," the camshaft switches grind from the less aggressive to the more aggressive.
What determines this point? Hours and hours dyno testing and tuning. If it is set too low, the more aggressive grind will kick in early, bogging down the engine (think "loping" at 3500 RPM). Too high, and the engine is missing out on valuable time it could be spending with the VTEC engaged. So all those fools who spent $400 on a VTEC timer running stock camshafts just so they could get their VTEC to kick in earlier- they're idiots. They just cost themselves a ton of midrange power. The stock crossover point is optimized for stock camshafts.
So when is a VTEC timer necessary? Easy- when you're no longer running stock camshafts.
If you want big power all motor, you go with one of the big players in the cam game- Toda Spec B and C, or Jun Stage 2 and 3, and you accept no substitutes. All (or at least 95%) of the 225+ all motor whp B18s are running these camshafts.
How does this relate to VTEC crossover point? Well, the VTEC grinds on these cams are so aggressive, that the VTEC point needs to be moved up- way up- usually to 6500-7000 RPM. These cams will also make power to 9500+ RPM (READ: Built motor). Run these in conjunction with high compression pistons (at least 10.5:1), and you'll have yourself an all motor wonder. And this, friends, is where torque in Hondas comes from.
So here's what we've learned:
The LS/VTEC suffers from a bad R/S, due to the fact that it utilizes an LS block with a R/S of 1.54:1.
A bad R/S is bad for the engine, especially at high RPMs
Hondas make power through revving, and high power through revving higher, high compression, and aggressive camshafts
Because of its R/S ratio, it is not recommended that you rev an LS/VTEC past 6750 RPM on stock internals- the redline of a stock B18A-B. With a fairly built bottom end, it is still not recommended that you rev an LS/VTEC past 7800 RPM.
As we just discussed, in order to get any considerable power out of an engine, aggressive camshafts are a must. In order to get any benefit from aggressive camshafts, the ability to rev the engine high is a necessity. How valuable is VTEC if you can only use it for the top 1000 RPM of your powerband?
LS/VTEC is a fad, and I predict that it will be all but a pleasant memory in a few short years. As soon as kids start snapping rods and putting pistons through cylinder walls, they'll realize how important good engine geometry is. Add that to the fact that they're running stock cams (because it's all their engine can safely handle) and getting burned by kids running Todas or Juns, and they'll wish they had just stuck with their trusty B18C.
Never have I said that the LS/VTEC is an awful motor, and that no one in their right mind should build one. LS/VTEC has been hailed as the biggest thing to hit Honda tuning in years. Import Tuner, Super Street, Honda Tuning, and more have praised the ingenious design, marveled at its torque, and even showed you how to construct this beast in the comfort of your own home. Never do they mention its drawbacks or its subsequent limitations. The intention here is not to discourage someone from building an LS/VTEC. Rather, it is intended to give someone considering one of these hybrids some things to keep in mind before diving into the costly process of building an engine.
Like I said, if it was all that great, Honda would have done it in the first place.
Sources/ Influences
Larry at Endyn
"The best engine will be the best series of compromises."
Katman at FF Squad
"So please... Don't steal any of our cars again. Thanks."
Tuan at SHO
"The more you learn about the factors of making power, the more amazed you become at how good the stock engine really is."
-Josh-
Old 06-25-2003, 09:21 AM
pvang31019 pvang31019 is offline
lol....Myths
That must be his Unicorn
Old 06-25-2003, 09:53 AM
Kaiser's Avatar
Originally posted by pvang31019
lol....Myths
Can you please explain to me why it is a myth, maybe provide some links.. ?
Old 06-25-2003, 11:31 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Her you go...
Before You Bring Up Rod/stroke Ratio make sure you understand what it actually means and what it tells you about a bottom end. Also make sure you have a basic understanding of rotational kinematics.
For a basic description of Rod/Stroke Ratio:
http://www.hondaswap.com/forums/inde...=ST&f=1&t=6061
For the basics of rotational kinematics:
http://rockpile.phys.virginia.edu/arch14.pdf
Now whoevers little diatribe you quoted there, MIGHT have some weight, IF it hadn't already been PROVEN that frankensteins, when BUILT RIGHT, can stand on their own as well as a stock. ANY motor, is going to take a dump on you when you hammer it all the time. Not to mention, R/S while yes it is important, you have to think to yourself, "damn, there are many companies running much worse R/S's in their motors that hold up just fine"
Old 06-25-2003, 03:40 PM
Dude, did you know that teh all motor camp strokes their motors, not jsut bore, but strokes(making the rod longer) for more torque? That's what deckplates are there for. I know Erick runs a deckplated, strocked and way over bored motor in his civic. What's funny is that he revs happily to 11,000rpm.
Last they checked(nopi race), he was right around 2.3L wiht a still small bore.
ANd if the b18a/b or b20 is so bad, then teh b18c would be the same also. The r/s ratios from the GSr and LS are really close to each other.
Don't believe all the hype you here on the internet. ls/vtec's are great if built right just like any other motor. Saying ls/vtec, is not reliable is like saying longer gears are better for boost
Old 06-25-2003, 10:10 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
::yawns:: read it before...still love ls/vtec motors.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 06-26-2003, 12:58 AM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
P= (TR)/5252
Therefore:
WRONG.
First of all, this is a misleading information, second of all, you cannot just plug in any torque number and RPM into this formula and last, the conclusion is not true since you can't just input any torque and RPM number.
The formula mention above is for horse power @ peak torque, not horse power (by the way, whoever trying to talk about HP please be specific on what type of HP because it will cause confusion and misleading).
If you want to find out the HP @ Peak Tq, you will need to know your engine output spec.
ex.
120 HP @ 6000 RPM-not important in this formula
110 Tq @ 4000 RPM
(110 X 4000)/5252
=83.78 HP @ Peak Torque
I have no common on the preformance and reliability of a LS/VTEC enging simply because I don't really care and just want to see someone fxxked up and learn from their mistakes, I just want to make clear of this information so no one will be misleaded or confuse by it.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 06-26-2003, 01:37 PM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Man...I wish member and moderator of old Baldy was still around here. He would educate you all on the perils of an LS/Vtec motor. Not that his troubles are typical of ALL LS/Vtec builds, but his was professionally built by a reputable shop, and inspected by a VERY knowledgeable gearhead(ME) and the setup looked good. Couple months later and his motor was toasted. After a rebuild and another failure, he gave up and scrapped the idea. Like I said, his setup may not be typical of ALL LS/Vtec builds, but that's one bad experience I've witnessed first hand
There's no replacement for displacement...No, not even a turbo.
