Old 03-12-2014, 11:04 PM
MarcoMoto's Avatar
MarcoMoto MarcoMoto is offline
2007 Honda RS250RW Scot team/Dovisioso (Hasegawa)
I am a week or so into this build, my first posting on AF,
so go easy on me... First is the box shot, parts bins, and
Top Studio detail-up set. I am almost complete with the engine,
added PE boltheads, and washes to bring out the detail.
Scratchbuilt wiring and the clutch linkage spring as well.. Enjoy!
Marco
Last edited by MarcoMoto; 03-17-2014 at 12:14 PM. Reason: attachments are thumbnails
Old 03-13-2014, 11:25 AM
germaniteen germaniteen is offline
Re: 2007 Honda RS250RW Scot team/Dovisioso (Hasegawa)
Marco, you have to post your images to another host (imageshack or photobucket...etc). Then using <img>your link</img> to solve your issue
Thanh Nguyen
Old 03-13-2014, 07:14 PM
Still see absent great pix,Marco. Here is the result.
Old 03-14-2014, 04:48 PM
John18d John18d is offline
good start marcomoto - I will follow your post
John
Old 08-21-2014, 01:45 PM
MarcoMoto's Avatar
Made some progress here... I added welds to the frame and swingarm,
completed my shock in 2 parts, so I could install the sensor later..
Enjoy! Marco
Old 08-21-2014, 09:03 PM
Marco - how did you do the welds on the swingarm ??
Please explain
Thank you
John
Old 08-21-2014, 11:36 PM
MarcoMoto's Avatar
Thanks John,
I used a product called Magic Sculpt epoxy putty to lay
Down a narrow bead, then made the weld impressions
With a tiny brass tube cut at a angle at the tip..
Old 08-22-2014, 06:39 AM
sportracer02's Avatar
great progress so far !!
Are the posts, where the model is fixed to, handmade?
Micha
Old 08-22-2014, 10:12 AM
MarcoMoto's Avatar
Thanks sportracer! Yes, I machined them on a lathe
When building the stand. 1/4" aluminum bar stock..
Marco
The Following User Says Thank You to MarcoMoto For This Useful Post:
sportracer02 (08-26-2014)
Old 08-24-2014, 05:37 AM
evilduse's Avatar
evilduse evilduse is offline
This might be your first post, but you obviously know your way around a moto build! The jig you made for holding the 'in progress' frame looks pretty handy. May have to do one of those the next time I do a moto. Impressive start to this bike.
Old 08-25-2014, 08:46 AM
Zonic2001's Avatar
Zonic2001 Zonic2001 is offline
Love those moto vertical post holders. Can you make me some? I'm willing to pay for them if you can ship them to Florida. PM me if you don't want to post in here a reply. I'm into motos too.
Old 08-25-2014, 12:19 PM
MarcoMoto's Avatar
Thanks, Duse and Zonic! Appreciate your comments..
I'll try to post often, as this build is moving rapidly!
@Zonic: Sent you a PM re the building base.
Old 08-25-2014, 03:57 PM
MarcoMoto's Avatar
Small update...
I have completed the airbox/carbs assembly, cutting out a large section
of the housing to install the PE mesh. In reply to a few user requests, I'm posting a better view of my building board. Each aluminum post is height adjustable after measuring and drilling for the the axles, and pivot. I use a small hammer and block of wood to tap the post until it is at the right height.
Now the bike can be handled sideways, even upside down if necessary, by holding it only by the base.
Old 08-26-2014, 09:59 PM
Really nice clean work Mark
what type of "washes" are you using??
Thanks
John
Old 08-27-2014, 12:48 PM
MarcoMoto's Avatar
Thanks, John!
I'm using a mix of Tamiya X-18 semi gloss black, water, and a drop of clear liquid dish soap, to break the surface tension and allow the wash to flow smoothly. When I'm happy with how it looks, I clearcoat it to protect it with either X-22, or a gloss lacquer. Gravity plays a role here, so I make sure the part is flat so the wash can dry evenly.
Hope that helps, Marco
Tags
2007 , dovisioso , honda , rs250rw
