Old 03-11-2014, 06:01 AM
jamesmetairie jamesmetairie is offline
Question 1998 coil,wire ,plug question=-
1998 210,000 miles, 3.1.litre.
Always ran great. Replaced wires and plugs with delco 1 year ago.
Recently started missing at almost all speeds including idle.
Is it possible if finding a no spark on a spark plug to use a different plug and wire to confirm it is a problem coil?
Does a dirty injector have the same feel?
What would you guys do?
Thanks for any advice.
Old 03-11-2014, 07:16 AM
rhandwor rhandwor is offline
Re: 1998 coil,wire ,plug question=-
Try using a different plug and wire before replacing the injector. Normally if a coil is bad both plugs will quit firing.
Old 03-11-2014, 10:21 AM
Tech II Tech II is offline
Get a spark tester and do a coil output check......
Old 03-12-2014, 05:19 PM
Question Re: 1998 coil,wire ,plug question=-
replaced wires and plugs.
plugs highly worn with only 20,000 miles .
car ran fine on the street up to 40 mph.
then jumped on interstate and car blogged down quickly.
,missing,etc.,with ses light occasionally flashing.
turned off engine and car will restart ,but ses light still on.
shady tree mechanic don,t want to use any kind of spark tester ,etc.
he says it,s 100% wires and plugs from his experience.
Old 03-12-2014, 08:44 PM
Smile Re: 1998 coil,wire ,plug question=-
mechanic installed one new coil and it seems to work.
drove on the Interstate up to 75 mph and no misses anywhere.
mechanic cleared the ses and it didn,t return.
thanks for the advice guys.
