Old 03-11-2014, 02:45 AM
nascar49's Avatar
nascar49 nascar49 is offline
Send a message via AIM to nascar49 Send a message via Yahoo to nascar49
Revells 2013 Boss 302 Mustang
And a quick mock up to see the ride height, and it looks like its going to need to be lowered a little bit
Pheedens Garage on Youtube
https://www.youtube.com/channel/UC4j...J8vUP1ZaHP32ig
Old 03-11-2014, 10:03 PM
nascar49's Avatar
Re: Revells 2013 Boss 302 Mustang
up first, a little more work on the engine, after looking at the pic, I see I need to touch up the valve covers in the holes and a few other spots , I used metalizer gun metal instead of a black , and I used Tamiya Brilliant Blue , I do want to make comment about this kit, the flash and mold/seems lines are not bad so far, but compare that to the Revell AG BMW DTM kit , that thing is horrendous in the way of mold and seem lines.
Old 03-14-2014, 03:14 AM
nascar49's Avatar
I am sure you are waiting to see what shade of purple I am going with, well here it is, I am also going to be using the primer as well, thought I would give it a try
And started work on lowering the ride height , up first was the front, cut down the attachment point
and in the rear
and cut down the springs
and removed a little bit off the top of the axle , just a tad bit to much as I cut through
and now the new ride height, I wanted to go just a tad bit lower in the front, but that would mean having to break out the dremel and grinding down the under side of the wheel well, but there is not a lot of plastic that can be removed without going through
And some primer shots , and working on removing the mold lines, which are not that bad, also deepened the panel lines
Old 03-14-2014, 06:53 AM
Eric Cole's Avatar
Eric Cole Eric Cole is offline
Looking great so far. Looking forward to more progress. Good job lowering it also.
Eric Cole
Other Model Pictures Here:
http://s5.photobucket.com/albums/y197/justdande/
Old 03-16-2014, 04:35 PM
Twowheelsrule Twowheelsrule is offline
Enjoying the build so far! Thanks for showing lots of details!
Old 03-16-2014, 07:45 PM
ChristopheB's Avatar
ChristopheB ChristopheB is offline
Ah, the boss! I need this kit!!
Christophe.
Old 03-17-2014, 07:51 PM
nascar49's Avatar
Painted the body over the weekend, had some trying to get the camera to show the true shade
Old 03-20-2014, 11:28 PM
nascar49's Avatar
Body is cleared and polished, need to paint the trim next, sorry, no pic, having a hard time getting the camera to capture the color , I need to try and take a pic outside and see if that helps
Moving on the chassis, and well, I am not sure if I got even close, I split the difference on the under body color, I used OD green and a brown, just dont ask me at what ratio, it started out as OD green, didnt like it, so I tired doing a light coating of brown, didnt like that, so I mixed the two together and got what you see.
And started on the the interior
