Old 03-10-2014, 02:21 PM
yakko yakko is offline
Blazer sputtering and backfiring after startup
99 V6 Blazer.
Here's what's happening... when I start the Blazer, put it in reverse, back out of the driveway and then put it in drive and apply the accelerator, the truck begins to sputter and backfire and tries to stall and has little power. After about fifty to a hundred feet of this, the issue clears up and all is good until the next morning.
Things I've noticed: it doesn't seem to happen in reverse. It only does it after sitting for a long time (such as overnight). Once it clears up, it seems to be perfectly fine.
Any advice would be appreciated.
Old 05-05-2014, 02:44 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Blazer sputtering and backfiring after startup
Do you have an AC-Delco Distributor Cap and Rotor? Are you getting any "Check Engine" Lights or codes? I had a lot of the same type of issues with an AutoZone Duralast Distributor cap that was only 6 months old.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 05-05-2014, 04:57 PM
DeltaP DeltaP is offline
I agree w/ Rick on the Delco cap and rotor. My '00 van, 4.3L would act the same way and consume a cap and rotor yearly. Had to be Delco. Make sure the rubber seal is good on the dist base to keep the cap sealed and moisture out. Gotta have regular fuel filters changes too. At least annually.
Old 05-05-2014, 05:02 PM
Big Tall Dumb Ass
Here is my tale of woes:
http://www.automotiveforums.com/vbul...d.php?t=975186
Still runing the same AC-Delco Cap for over 4 years without ANY problem!
